wm.link_append() never appends despite link=False #38924
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#38924
Windows 7
Broken: 2.69 (and at least 2.67, 2.65, 2.57)
bpy.ops.wm.link_append()
called from script ignores the link-argument and always links. If you try it with a scene, you can't even make it local in UI afterwards. It works fine via File / Link/AppendExact steps for others to reproduce the error
Example code:
Added subscriber: @CodeManX
This was actually reported earlier, but closed as invalid:
https://developer.blender.org/T30172
It might be platform-specific.
Added subscriber: @ideasman42
I tried this and
link
option is respect as it is from running the operator directly.Could you upload sample blend files which fail?
Also possible (but unlikely) a bug for ms-windows, tested on 64bit Linux.
Not being able to make local looks like a real bug though, checking on that
correction - its not implemented.
id_make_local
Note that using
from python is quite limited, we have an API for linking which lets you inspect data in the blend file.http://www.blender.org/documentation/blender_python_api_2_69_release/bpy.types.BlendDataLibraries.html
It is indeed a Windows problem, it occurs if a Blender path with slashes is used:
A standard Windows path with backslashes works.
This should be made to work (or at least give some error on invalid args),
but since theres already a python api for this and it only fails when called with incorrect args, Id postpone any changes here until after 2.70
Added subscriber: @Sergey
@ideasman42, mind looking into the fix?
This issue was referenced by blender/blender-addons-contrib@1eb1351976
This issue was referenced by blender/blender@1eb1351976
Closed by commit blender/blender@1eb1351976.
