Boolean modifier freeze #39151
Reference: blender/blender#39151
Tested on various HW and OS (Win64, Linux64)
Latest tested version: blender-2.70-c17acf1-win64 (official daily build)
Broken: somewhere in 2.70
Worked: (optional) 2.69
In some cases boolean modifier (difference) causes Blender to freeze (infinite loop type, full load on one CPU core).
In test blend file is also used Solidify modifier, however booleans freeze even if Solidify is applied with thickness value near freeze case and manipulating objects by grab and rotate.
Open attached file, and either run animation (alt-A) or set Solidify modifier thickness on cube.001 to >1.7.
boolean_hang_1.blend
Added subscriber: @jucas
Added subscriber: @ignatz
I can confirm that the file in question is causing Blender 2.7 to freeze up. This file does not cause Blender 2.69 to freeze...
The animation of the thickness setting of the Solidify mofifier of object cube.001 is causing the problem. At verious points in the animation cycle if one applies the modifier and then examines the resulting mesh it will be seen that there are faces with normals pointing in the wrong direction. Not only that, but the resulting mesh is also passing through itself over time, having faces that are cutting through other ones. It is also questionable whether or not the resulting mesh from the solidify animation over time is always completely closed and manifold (I didn't look that closely).
In any case, the boolean modifier in Blender 2.69 does seem to tolerate this bad mesh (even if the visual result is still unstable and terrible).
The boolean modifier in Blender 2.70 does not tolerate the bad mesh and freezes the whole program.
This issue was referenced by blender/blender-addons-contrib@94379277dd
94379277dd
Closed by commit
94379277dd
