Difference of position of cloth animated mesh between viewport and render result #39195
2 Participants
Reference: blender/blender#39195
Win 7/64, AMD HD 6850
2.70 (Can't remember it ever worked.)
A cloth animated mesh that is part of a group instance is not rendered at the correct location as in the viewport.
Open the attached file and render. Problem: The cloth is rendered at a position different to the viewport.
Test_116.zip
Note that layer 1 contains only a group instance. Switch to layer 2 to see the group definition: The cloth has been animated by a cloth animation, and the cache has been baken. However, as the viewport can display the cloth within the group instance in layer 1 at the expected location, the renderer should be able to do so, too.
Added subscriber: @willi-2
Added subscriber: @Sergey
First guess is that it happens because of order in which object position and cache load happens in case of dupli-stuff physics. Will check whether it's solvable with the current design.
Spend quite a while trying to solve the issue. It is actually a limitation of the render database creation in Blender Internal. Technically it's caused by the render pipeline changing object's matrix before evaluating modifier stack. It's possible to support point caches working here, but then file from #38801 wouldn't work.
Some bigger render database refactor is needed. We'll need to do it for granular depgraph and copy-on-write projects anyway, so better solve all the issues all at once.
Added the note in our TODO list: http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Render#Render_Engine
Thanks for the report, but for now will consider this is a TODO.
