Strange bug with shape keys in BGE #39401
2 Participants
Reference: blender/blender#39401
WIndows 7, 2.4ghz celeron cpu, 2gb ram, Geforce8400GS
2.7
Loading a scene, which adds a new scene with a background scene, causes the shape key animation (from the background scene) to freeze at a specific point; even though there is no call for the animation to play.
Everything was working fine until I removed a Message actuator from a object that has animated shape keys and 2 other actuators. The bug doesn't show up unless the current scene replaces itself with a scene, that then loads a background scene with the object with the shape keys.
I conducted a test where I put back the Message actuator I took out. Unfortunately, it did not fix the problem. I am thinking that taking out the Message actuator the first time was just a coincidence. I conducted another test with a new blend file, and set up a similar situation across 3 scenes. I could not reproduce the bug. Either this bug is completely random or am I missing something? See strange_shapekeys.jpg. There is no code or logic bricks telling it to do that.
\This doesn't happen if the Scene.HUD or the Scene.L1 is loaded first. The problem is carried over to Scene.L2 and Scene.L3 if the ball isn't lost. If the ball is lost, it plays the animation normally. The problem is both in the view port and standalone.
I conducted another test by removing the action actuator from the "Ready? Begin!" object. The bug still shows up, so the problem isn't from the action actuator. The problem went away after I removed the animation keyframes from the shape key value properties. Now there is no animation to play; but, it proves the problem is in or connected to the animation data.
I deleted all the shape keys and animation, and tried to reproduce the original animation (ended up doing something different), and I still end up with the same bug (see strange_shapekeys2.jpg).
After a thorough investigation, I found the problem. The issue is the starting animation frame between scenes. Scene.Intro had a starting frame of 0, Scene.HUD had a starting frame of 1, and Scene.L1 had a starting frame of 0. For some reason, changing scenes in the bge that have a different start frame causes this abnormality to happen. The issue is solved; however, the bug remains.
I tried to included my project "blockbreaker" with the blend and animation files; however, there was a upload error because of a size limit. If you still need a blend file, I will try to get one uploaded when I have the oportunity.
Added subscriber: @remnar
Added subscriber: @brita
You have made several tests to pin down the origin of the bug, can you upload a minimal file? Take out everything that is not related.. textures.. etc. Or make a new file with that start frames inconsistency that you found to see if the error is reproducible.
@renmar I really need a minimal file, or I will waste too much time with this
No response, closing.
