Freestyle: Curve with extrude>0 causes warnings in console #39669
Reference: blender/blender#39669
Win7/64
Broken: all (since 2.67)
If a 2D curve is extruded and freestyle is enabled, there are many warnings like these in the console when rendering:
Open Freestyle_warnings.blend, render, and look in the console. The render result might be ok, but a warning says there's something wrong or should be improved.
Added subscriber: @willi-2
Thank you for filing the report.
The reported problem is not considered a bug. The series of warnings is intended to inform users of potential problems that exist in the input scene data.
To my knowledge, extruded curves contain many duplicated vertices and edges. Freestyle tries to remove them to polish mesh geometry for better line rendering quality. The warnings tell you that there are duplicated edges in the mesh data.
If you convert the curve object into a mesh and apply the Remove Doubles operation to it, then the warnings won't show up.
Ok, accepted that it's not a bug. Though I'd like to know why there's no warning after conversion to a mesh even without removing doubles. Does the freestyle component get a curve object as input, or does Blender first convert the curve to a mesh before passing it to the freestyle component? If it's the latter, I don't understand why there's no warning after I convert the curve to a mesh. (maybe only a curious programmer can ask this, but to me the difference doesn't make sense)
Thanks for looking into it anyway!
Added subscriber: @ideasman42
You are right, and I was overlooking the fact that the warnings could be suppressed by just converting the curve into a mesh without removing doubles.
Freestyle receives from Blender a set of faces (triangles and quads). Curves are converted into faces by the Blender Internal (BI) rendering engine, so Freestyle has nothing to do with the conversion.
A closer look into the issue revealed a subtle difference between the manual curve-to-mesh conversion and the automatic conversion by the BI with regard to the normal of filled faces at both ends of extrusion. With the manual conversion, the filled faces have a normal in the outward direction as expected. With the automatic conversion, their normals are flipped and in the inward direction for some unknown reason. These flipped face normals cause a discontinuity of surface which then leads to the warnings of duplicated edges in Freestyle.
Now the issue has turned out to be in the automatic curve-to-mesh conversion whose result is inconsistent with the manual conversion. Note that this issue is unlikely to result in negative visual artifacts, because it is usually okay to have separate filled faces from the surface made along the extent of extrusion. But consistency is always nice to have.
Campbell, could you please take a look at the difference in the normals of filled faces documented above? I would file a separate issue report if appropriate.
Changed status from 'Resolved' to: 'Open'
"...whose result is inconsistent with the manual conversion"
Something like this was my suspicion. Thanks for the explanation in a closed thread. Very much appreciated.
Added subscriber: @kjym3
Campbell, could you please take a look at the reported problem in curve-to-mesh conversion? It looks like a general issue not specific to Freestyle.
@kjym3
I checked the mesh and its not making duplicate edges,
At least this works as expected.
I expect this is caused by freestyle loading
ObjectRen
,VlakRen
... ?I managed to visualize the curve-to-mesh conversion inconsistency in question.
The attached .blend file below renders a cube in two colors: front faces in blue, and back faces in red.
to_mesh.blend
When the cube is represented by an extruded 2D curve, the face filling the Front of the extruded curve appears in red.
When the curve is converted into a mesh, the same face appears in blue. That is, the face normal is flipped.
This difference is what I was trying to highlight in a previous comment of mine (link ):
Note that flipped face normals are the problem, and not edge duplicates.
@ideasman42, I was unable to track down the cause of the documented issue. Should I file this as a bug?
@kjym3, yep, this does look like a bug on its own.
however the winding direction of the face is correct AFAICS,
So somehow the normal is pointing the wrong way when rendering (which is very strange)
Note: BI has its own code to convert displists to faces, perhaps bug is there
@ideasman42,
I made an attempt to fix the wrong normals and submitted a patch: D532. Flipping of normals (or the z-up direction to compute the normals) is found here and there, so I tried to make them consistent. Tested cases include:
The same tests were done with a 3D curve with filled caps. None of the tests resulted in a wrong normal (no warnings from Freestyle either). Hope this helps.
Fix D532 was done by commit
f8554ed61a
. Thank you @ideasman42 for the code review!
