Blender renders disabled Render Layers using Blender Internal #39763
6 Participants
Reference: blender/blender#39763
win64 i7 gtx titan
blender-2.70-b179647-win64
Blender renders the Render Layer even though it is disabled.
Open attached file, press F12. Blender is rendering the disabled render layer.
Thank you.
render_layer_settings_ignored.blend
Added subscriber: @dragostanasie
This bug is present in 2.7 official as well.
Added subscriber: @Harvester
Hello Maverick, I've tried to load your test file into Blender 2.7.0a (Hash
f93bc76
) 64bit under Win7 Pro 64bit and it doesn't open getting the following error message: "File format is not supported in file C:....\desktop\render_layer_setting_ignored.blend". The console doesn't give any further details on the origin for the error.Anyway, I tried to recreate your rig in a simple configuration with two scenes, one running BI and the other one Cycles, compositing layers in the Cycles scene and using two layers from the BI and one only from the Cycles scene (the other duplicated layers has been disabled in Cycles). I then activated and deactivated layers in both BI and Cycles scene but couldn't reproduce your problem. Perhaphs I haven't understood it correctly; if you disabled the BI layer then it shouldn't be rendered at all. In fact from your screenshot the only data is coming from the Cycles render.
Please, find attached the test blend file:
render_layers_testfile.blend
Hi harvester.
Just try using the official 2.7 win64 version. I tried again and it shows the same bug. Let me make a quick resume on how to recreate it though.
Make 2 scenes, one with Cycles and one with BI.Each scene must have just one render layer (the default one).
Disable the render layer of the BI Scene.
Switch to Cycles Scene and Mix the Scenes in the Compositor.
Press F12. Both scenes will render even though BI is disabled.
However after rendering the Compositor will not show the result for the disabled BI render layer (which can be seen in my screenshot as well).
(In my file the BI scene has a Suzanne with SSS, AO with high settings just to be sure you can see it is rendering)
Maverick,
The Blender 2.7.0a (Hash
f93bc76
) 64bit is the current official version. Anyway, I ran a test on the Blender 2.7.0 (Hash:19e627c
) 64bit previous official version following your above instructions and these are the results: BI renders the render layer even if it has been disabled, in fact if I then switch from the Cycles scene in the Compositing view to the BI one I can see the BI scene rendered in the Image editor view, and if you click on the render layer drop down list between the Slot number and the Passes it shows nothing, in the sense that there isn't any Render layer available, which makes sense because we disabled it. Effectively what's strange is that the BI scene was rendered anyway.Tested also on Blender 2.69.0 r60995 and on Blender 2.62.0 r44136. They all behave the same way as above illustrated. So, despite is might not be a desired behaviour and perhaps it may be addressed by the developers, I wouldn't consider it totally a "bug", but I agree that it doesn't make any sense to disable a layer and get it rendered anyway with consumption of resources and time (I am thinking of very complex scenes not just a plane, a cube and a lamp). Let see the developers' comments.
Thanks harvester,
So indeed you can confirm this bug.
The attached file is a scene as simple as possible which can still replicate the bug.
This is requested by the developers so they can easily check what is wrong.
In practice my file had 6 scenes, heavy geometry and much complex Compositor nodes and it rendered disabled render layers which increased the time considerably.
The only "workaround" was to delete that scene without saving the file...
Added subscribers: @brecht, @LukasTonne
@brecht: i can't get my head around all these render layer flags and BI vs external situation ...
One thing i noticed is that all render layer flags are copied to the
Render.layers
list - maybe it would be preferable to make this a filtered list to begin with, so that render engines don't ever have to worry about disabled layers?It's in
ntree_render_scenes
that it looks over the compositing nodes to render the needed scenes. It doesn't check if there actually any enabled layers for the scene, or any of the other checks that happen inRE_is_rendering_allowed
for the main scene.Then later on in
render_result_new
it will add a render result even if no layers are enabled for some special cases.Copying only the enabled layers is probably fine, but either way a check for this cases needs to be added somewhere.
Thank you Lukas and Brecht for looking into this matter.
Will look into this.
This issue was referenced by
295c37caa4
Closed by commit
295c37caa4
