Cycles smoke adaptive domain visibility #39804
Reference: blender/blender#39804
Windows 7 X64, dual Zotac Geforce GTX 670 4 Gb
Broken: 2.70, Hash :
4ed16bc
When using smoke adaptive domain with Cycles in closed area, I can see during animation that the adaptive domain is visible as occlusion on the walls.
Here a picture of the effect bug :
http://matthieubarbie.files.wordpress.com/2014/04/capture.png
http://matthieubarbie.files.wordpress.com/2014/04/cycles_fluids-0047.png
The file without smoke cache : https://docs.google.com/file/d/0B2ylYG5fzOLLR0RNWV9Bc01jd3c/edit
Added subscriber: @matthieubarbie
Added subscriber: @brecht
The problem comes from the wall behind the domain using a different random number pattern. If you take more samples to lower the noise, the problem should go away.
We could try to avoid this problem by not increasing
rng_offset
when we go through fully transparent surfaces and volumes, though it will still be a problem with partially transparent cases which is what you have with smoke. Using correlated multi jitter should not have this problem but we can't easily make that the default. Not sure how to solve this best yet.Hi,
Sorry for the delay, I tried the correlated multi jitter, same result. Of course, will try with no adaptative domain or no domain offset to check too. When tested, I'm coming back to you.
Matt
ps : personal question, smoke rendering will be support by branched path tracing and gpu too ? also does Cycles will support stereoscopic rendering ( 2 buffers rendering at the same time with two frame output) ?
Hi,
Found something else, stranges shadows with volume with adaptive or no-adaptive domain in last build. Below, a link to the datas need to see the bug and the scene used for that :
https://docs.google.com/file/d/0B2ylYG5fzOLLX2g1RzFLV1BnNDg/edit
Matt
This issue was referenced by
0780f5915b
Closed by commit
0780f5915b
