Incorrect render layer visibility display for animated render layers #39828
Closed
opened 2014-04-21 14:43:16 +02:00 by Willi · 13 comments
Win7/64, AMD HD 6850
since 2.57b
When navigating forward from a key frame for visibility of render layers to another key frame, the display does not match the actual values:
Actually, only layer 2 is visible.
  • Open attached file: At frame 0, only render layer 1 is visible. At frame 1, only render layer 2 is visible.
  • If you navigate from frame 0 to frame 1, the display (as shown in screenshot) incorrectly indicates both render layers are visible, whereas, when navigating from frame 2 to frame 1, display is correct.
RenderLayers.blend
**System Information** Win7/64, AMD HD 6850 **Blender Version** since 2.57b **Short description of error** When navigating forward from a key frame for visibility of render layers to another key frame, the display does not match the actual values: ![Bild_309.JPG](https://archive.blender.org/developer/F85515/Bild_309.JPG) Actually, only layer 2 is visible. **Exact steps for others to reproduce the error** - Open attached file: At frame 0, only render layer 1 is visible. At frame 1, only render layer 2 is visible. - If you navigate from frame 0 to frame 1, the display (as shown in screenshot) incorrectly indicates both render layers are visible, whereas, when navigating from frame 2 to frame 1, display is correct. [RenderLayers.blend](https://archive.blender.org/developer/F85517/RenderLayers.blend)
Author
Author
Added subscriber: @willi-2
Added subscribers: @brecht, @ideasman42, @Sergey, @mont29
Iirc, this should not be animatable? Brecht, Campbell, Sergey, can you confirm?
From my understanding the things they shouldn't be animatable. But i might be wrong.
We disabled animation of scene layers because it gave dependency graph issues I think. This render layer value should not suffer from that particular problem.
I think the problem here is the way this RNA property interacts with the animation system. Because it's not allowed to have zero layers enabled, the f-curve that disables the first layer will be ignored when going from frame 0 to 1. That's a tricky issue as well though.
We disabled animation of scene layers because it gave dependency graph issues I think. This render layer value should not suffer from that particular problem. I think the problem here is the way this RNA property interacts with the animation system. Because it's not allowed to have zero layers enabled, the f-curve that disables the first layer will be ignored when going from frame 0 to 1. That's a tricky issue as well though.
@brecht, it doesn't seem render engine supports changes in render layers visibility. Here's a sample file which is free from the mentioned bug in animation but which fails to render animation{F85610}.
AFAIR, this bits are copied into Render and not being updated. We could support this, but isn't it a TODO and meanwhile marking layers as non-animatable is ok-ish thing?
@brecht, it doesn't seem render engine supports changes in render layers visibility. Here's a sample file which is free from the mentioned bug in animation but which fails to render animation{[F85610](https://archive.blender.org/developer/F85610/render-layer-visibility.blend)}. AFAIR, this bits are copied into Render and not being updated. We could support this, but isn't it a TODO and meanwhile marking layers as non-animatable is ok-ish thing?
Author
I see. I'll keep layer 20 visible all the time. Should be a temporary workaround. Not essential for me anyway, so I'll do it differently if you decide to drop animatability of render layers.
Thanks.
I see. I'll keep layer 20 visible all the time. Should be a temporary workaround. Not essential for me anyway, so I'll do it differently if you decide to drop animatability of render layers. Thanks.
I'm OK with this being marked non-animatable for now.
This issue was referenced by blender/blender-addons-contrib@14ab812da5
This issue was referenced by blender/blender-addons-contrib@14ab812da55ad08bc00f90fe0b9efa91c60daa71
This issue was referenced by 14ab812da5
This issue was referenced by 14ab812da55ad08bc00f90fe0b9efa91c60daa71
Bastien Montagne self-assigned this 2014-04-23 16:23:04 +02:00
Closed by commit 14ab812da5.
5 Participants
Reference: blender/blender#39828
