install_deps.sh fails when compiling OSL #39938
7 Participants
Reference: blender/blender#39938
Tested on Xubuntu and Ubuntu 14.04
Broken: currently
Worked: prior to April 24 2014
From a clean install (i.e. no Blender source, no /opt/lib/ or ~/src folders), follow the standard build instructions for Ubuntu up to and including the point where you run install_deps.sh
Troubleshooting so far:
Problem appears to be from changes introduced to OSL's src/cmake/modules/FindIlmBase.cmake file on April 24 2014, diff is here:
17ce27739b (diff-10b22e8cc61b4493866c72933aeafa5c)
Regressing the changes to FindIlmBase.cmake manually and re-running install_deps.sh with "git reset --hard" commented out of the compile_OSL() function got OSL building again successfully.
Can confirm that install_deps.sh followed the "else" path through these two lines of FindIlmBase.cmake - these are commented out in the current non-working version:
Not sure how to proceed from here myself but it appears you can feed CMake a var with the correct library names - ILMBASE_CUSTOM_LIBRARIES -- I'm not sure of the exact syntax to do this from install_deps.sh otherwise I'd keep hacking. Over to you!
Added subscriber: @quollism
Thought I jagged a fix for this but I didn't. Could be helpful to know this all the same:
Tried changing this part of install_deps.sh compile_OSL() function:
To this:
This mostly gets OSL compiling again, but it errors near the end:
[ 97%] Building CXX object src/testshade/CMakeFiles/testshade.dir/testshademain.cpp.o
Linking CXX executable testshade
/usr/bin/ld: CMakeFiles/testshade.dir/simplerend.cpp.o: undefined reference to symbol '_ZN7Iex_2_17BaseExcD2Ev'
/opt/lib/openexr/lib/libIex-2_1.so.11: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make- [x]: *** [src/testshade/testshade] Error 1
make- [x]: *** [src/testshade/CMakeFiles/testshade.dir/all] Error 2
make- [x]: *** Waiting for unfinished jobs....
[ 98%] Building CXX object src/testrender/CMakeFiles/testrender.dir/simplerend.cpp.o
[100%] Building CXX object src/testrender/CMakeFiles/testrender.dir/testrender.cpp.o
Linking CXX executable testrender
/usr/bin/ld: CMakeFiles/testrender.dir/simplerend.cpp.o: undefined reference to symbol '_ZN7Iex_2_17BaseExcD2Ev'
make- [x]: *** [src/testrender/testrender] Error 1
make- [x]: *** [src/testrender/CMakeFiles/testrender.dir/all] Error 2
make: *** [all] Error 2
ERROR! OpenShadingLanguage-1.4.0 failed to compile, exiting
So whatever the fix for this is, it's not that. OSL builds just fine with the older version of FindIlmBase.cmake though. Go figure.
Added subscriber: @mont29
I’d like to get the log of the error in install_deps from the unchanged (trunk) version…
Also, did install_deps build openexr, or did it installed it from ubuntu's packages?
install_deps builds both IlmBase and OpenEXR itself just fine.
Error log as follows:
Grmll… stupid CMake could at least spit out libs he does not find, instead of stupid var names!
Anyway, thanks for the log, will try and see whether I can reproduce that somehow :/
Added subscriber: @plasmasolutions
Added subscriber: @nudelZ
This issue was referenced by blender/blender-addons-contrib@9fb4c487ed
9fb4c487ed
Closed by commit
9fb4c487ed
.Added subscriber: @sunnystormy
Tried compiling version 2.75a on Fedora 22 today and got this:
After testing with a "sudo dnf install ilmbase" I found that I already have this package installed:
Any thoughts?
Added subscriber: @heath_petty
I'm seeing the exact same issue on Fedora 22:
