frequent repeatable crashes when rendering some files #40033
Reference: blender/blender#40033
LInux 64bit (fedora 20) Intel CPU, nvidia GPU
Broken: 2.70.?
f93bc76
,Worked: 2.70a
Specific Files crash on render
Download the file
Load it (even with factory settings and no autorun python scripts)
press F12
crash!
Added subscriber: @BassamKurdali
Added subscribers: @LukasTonne, @brecht
I can confirm the problem, this file contains an invalid UV Map node in STunnelConcrete_local_fake, and that node type did not exist yet in 2.70a.
What I suspect happened is that this file was saved in a recent git version, and then saved with 2.70a or some other earlier version that did not support the UV Map node. When you do that it seems to crash.
@LukasTonne:
node->storage
isNULL
after this, not sure how best to handle this. Here is a trick to make such nodes with invalid storage undefined, but I'm not sure it's a valid assumption that any node that defines a storage name also needs to have the storage pointer actually set.P56: (An Untitled Masterwork)
Hrrrm, this is nasty. @brecht's observation is correct: This happens when re-saving undefined node types, which are then expected to have full data after loading in more recent versions.
I added some code to prevent loss of undefined nodes when loading files. This happened before pynodes too, but in those days it always meant a version regression, so was fairly safe to simply remove such nodes.
With pynodes an undefined node type can also mean that you defined that node in a script which hasn't been run yet or had some error. In that case you wouldn't want to blatantly remove all the nodes and links, but rather keep a dummy around until the problem is fixed and the types become known.
The difference between the two is the use of bNode->storage data, which only works for classic DNA hardcoded nodes, it cannot be restored for undefined nodes (in principle we could keep a single memory block around, but that would only work in the simplest cases and easily cause trouble with potential future do_versions).
I agree with @brecht's solution, make such nodes undefined so the user can recover from mistakes manually and fix node setups at least. The only other option i think would be deleting such nodes as we did before pynodes, but that is more destructive for no real reason.
thanks both of you! at least this helps me fix the file and go forward.
not sure why the file was opened in an old version - was probably me hoping between computers.
Cool! removed/fixed: for the record, here were my steps:
1- open the file in 2.70a, remove the node, save out a second version (just in case other compatibility changes would be affected)
2- open the file in master, create a cube with a blank material, link material from cube to the original object with the bad node
3- save and reload the file: now the zero user dangerous material doesn't get saved, so the material browser won't crash blender
4- append the fixed material from step 1 and apply it to the object.
This issue was referenced by blender/blender-addons-contrib@79c345acc2
79c345acc2
Closed by commit
79c345acc2
.Hey Brecht, Lukas,
Can you reopen the bug?
the same file crashes again, since the following commit:
https://developer.blender.org/rB8b8d5a441f5815e83f83bacf8023e2cc3fbb2a04
somehow Image use alpha causes the file to crash. (with no changes in the file)
reverting to a commit or two earlier (I think it is a freestyle commit) causes the file not to crash again.
cheers,
Bassam
@BassamKurdali: that crash should be fixed now in {edd78fb3085e}.
In addition, a bunch of math nodes
are now showing up as undefined
in the material local_tunnel_emit
there are a bunch of simple math nodes
they are all undefined{F87610}
Changed status from 'Resolved' to: 'Open'
This issue was referenced by blender/blender-addons-contrib@3a8f1d5d8b
3a8f1d5d8b
Ok, that problem should be fixed now as well.
yay!!! brecht and lukas you rule :)
@brecht Thanks for all the fixes! Will close the task again now, can reopen in the unlikely event that there is still a problem.
