SSS direct/indirect turns out black in texture bake #40060
Reference: blender/blender#40060
openSUSE 12.3 64bits
NVIDIA 480GTX SC
Broken:
f300c15
Baking SSS Color works fine but Direct, Indirect or Combined results in black color
SSSBake.blend
Added subscriber: @zanqdo
The patch above - D503 - seems to work for your file. At least for SSS Color and SSS Direct:
Top Left: rendered passes (SSS Direct), bottom left: baked SSS Direct; Right: baked SSS shown in the UI
I tried the patch with a more complex object (caterpillar from Gooseberry) and I got a good result for color, but a very strange result for SSS direct (image layout same as above):
Catterpilar SSS Color:
Catterpilar SSS Direct:
Added subscriber: @brecht
I think the problem in that file is with the bump mapping, which fails due to missing ray differentials (
sd.dP
).A quick way to solve that would be to add this after
shader_setup_from_sample
:That's not quite right, really this should take the UV map used for baking and the image resolution into account, for that you could look at
bake_set_vlr_dxyco
in Blender Internal if you want, to see how you can get those differentials from a UV map. Getting that right would mainly help for OSL image texture lookups and advanced procedural textures that do antialiasing.Hi Brecht, with the latest changes to D503 the baking seems correct (SSS Direct):
So I'm not sure what did you mean by the bump maps (this file has no node connected to the Displace Input). There is a different issue where materials with a node connected to the Displacement input would fail to bake. I'll see if your suggestion fix that, and if so I will report it separately (or ask someone to do it, with real files ;) and post a patch ... Anyways, I shouldn't drag the other issue in here ;)
This file is using a bump node to set the normal for SSS, and it seems to cause issues with SSS indirect.
But yes, this should fix the displacement input as well since that uses the same mechanism and ray differentials as the bump node.
This issue was referenced by blender/blender-addons-contrib@83cdd5887f
83cdd5887f
Closed by commit
83cdd5887f
.Ah ok, I haven't tried SSS indirect. I tried your suggestion (sd.dP.dx, sd.dP.dy) and it works for displacement in the sense that it doesn't produce black. However it seems to simply bypass the displacement. I reported it here #40068 so we can discuss it there.
