Cycles-Bake shows black when Displament input is used #40068
Reference: blender/blender#40068
Trying to bake this file shows black:
displacement_height.blend
This also affects bump nodes (see #40060)
I tried @brecht's suggestion below, but it shows white, as if there was no displacement at all (instead of showing the checkers pattern expected from the file).
Now questions for @brecht:
Added subscriber: @dfelinto
Yes, that's what the du_dx, du_dy, dv_dx, dv_dy were for. Calculating them in Blender would be best I think since otherwise Cycles has to have some knowledge about what you're baking to (uv mapped image, vertex colors, ptex, ..), and that's currently nicely separated, so best keep it that way.
The formula to compute dP.dx and dP.dy is:
To compute dudx you take the difference between u at the pixel to the right of the current pixel and the current pixel, and similarly for the others values.
Added subscriber: @brecht
@brecht Cycles part is done - D510, I'm tackling Bake API part of it now. Feel free to review them separately.
In this example file you're using the (experimental, not supported yet) displacement and subdivision feature. Displacement does not actually need ray differentials to work, only bump mapping needs it. The problem here is with the subdivision which alters the mesh topology and so the mapping to the original mesh is lost. If this used a subdivision surface modifier instead it would work.
The subdivision code at the moment doesn't even support things like preserving UV maps on meshes, it's unfinished, so I would not consider that a bug, there's a reason it's hidden behind that experimental option.
A simpler test file: displacement.blend
Look at the result with latest D510:
It seems scaled up 2x. Now if I connect the checkers texture in the diffuse node too:
This issue was referenced by blender/blender-addons-contrib@31cb7e395e
31cb7e395e
This issue was referenced by blender/blender-addons-contrib@672cebf19a
672cebf19a
Closed by commit
31cb7e395e
