Autosmooth option causes assert failure when selected #40074
5 Participants
Reference: blender/blender#40074
Broken: (example: 2.69.7
4b206af
, see splash screen)Worked: (optional)
I am using Blender GIT Rev 2014-05-07-20-28-46-3a8f1d5 on a Fedora 20 64 bit box.
I noticed that if I switch to the Cycles Render Engine in most recent build and
then open the [3D View Editor > Properties Region > Item Panel] and select the
Auto Smooth tickable option then Blender will seg fault.
Attached my system-info.txt file, blend test file and the backtrace file.
backtrace.txt
CyclesAutosmooth_Seg_Fault.blend
system-info.txt
Added subscriber: @TerryWallwork-1
Added subscriber: @willi-2
Cannot reproduce with blender-2.70-a351ff7-win64
Well, I can’t reproduce it either here (Debian64 testing, latest master), neither with release nor debug+asan…
Ok since I posted the option has gone from the Properties Region area in the 3D Viewport.
It is still present in the Properties Editor > Object Data context > Normals Panel.
Pressing Auto Smooth in there crashes Blender for me (in both internal and cycles.)
This is with most recent build as of 13:35 may 8 2014
Updated backtrace for rev 2014-05-08-19-54-04-105aa67-x86_64 :
2 0x00000000023e0d3d in dm_ensure_display_normals (dm=0x7fffe0001878)
3 0x00000000023e1e65 in mesh_calc_modifiers (scene=0x6f1da38, ob=0x6f20368,
4 0x00000000023e353b in mesh_build_data (scene=0x6f1da38, ob=0x6f20368,
5 0x00000000023e386a in makeDerivedMesh (scene=0x6f1da38, ob=0x6f20368,
6 0x000000000252aa75 in BKE_object_handle_update_ex (eval_ctx=0x6b16a68,
7 0x0000000002586cc7 in scene_update_object_func (pool=0x7efc638,
8 0x0000000002714a40 in task_scheduler_thread_run (thread_p=0x7e3aa88)
The above is for a default scene with default settings.
Yep, but unfortunately a backtrace won’t help that much here… :/
Anyway, option is still (since ages) in Mesh buttons, Normals panel (I removed it from 3DView from Campbell's request).
Do you use builds from the buildbot, or your own builds? If the later, could you please try with an official build? and what would be your compiler version?
Added subscriber: @brecht
Are you compiling with WITH_ASSERT_ABORT enabled?
The
abort
in the backtrace indicates it's crashing onBLI_assert
. And when running a debug build, I can indeed see a messageBut it does not actually crash unless WITH_ASSERT_ABORT is enabled in the cmake configuration, and it's disabled by default.
mont29: yes sorry I just noticed it was removed in logs, sorry about that.
mont29: I am using my own builds, i will try with build bot (assuming there is an uptodate enough version and report back).
I am using the following gcc version according to gcc -v:
[terry@localhost ~]$ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/4.8.2/lto-wrapper
Target: x86_64-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-bootstrap --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-linker-hash-style=gnu --enable-languages=c,c++,objc,obj-c++,java,fortran,ada,go,lto --enable-plugin --enable-initfini-array --enable-java-awt=gtk --disable-dssi --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-1.5.0.0/jre --enable-libgcj-multifile --enable-java-maintainer-mode --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --disable-libjava-multilib --with-isl=/builddir/build/BUILD/gcc-4.8.2-20131212/obj-x86_64-redhat-linux/isl-install --with-cloog=/builddir/build/BUILD/gcc-4.8.2-20131212/obj-x86_64-redhat-linux/cloog-install --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux
Thread model: posix
gcc version 4.8.2 20131212 (Red Hat 4.8.2-7) (GCC)
brecht: Yes I am using Debug builds, and assert abort is active (which is intentional I was told that asserts should be reported, as asserts should never trigger). Also it has never triggered before and has always worked with assert abort active.
Output on the cosole when it happens is :
Read new prefs: /home/terry/.config/blender/2.70/config/userpref.blend
found bundled python: /home/terry/BLENDERBINARIES/Blender-2.70-GIT2014-05-08-19-54-04-105aa67-x86_64-GNU-Linux/share/blender/2.70/python
BLI_assert failed: /home/terry/BLENDER-GIT/EXTERNALSOURCES/BLENDER/source/blender/blenkernel/intern/DerivedMesh.c:1427, dm_ensure_display_normals(), at 'CustomData_has_layer(&dm->polyData, CD_NORMAL) == 0'
./blender: line 3: 9484 Aborted (core dumped) /home/terry/BLENDERBINARIES/Blender-2.70-GIT2014-05-08-19-54-04-105aa67-x86_64-GNU-Linux/bin/blender
So yes it looks like an abort/assert. I just assumed when it said core dump that was same as seg fault. I will make sure to highlight differently in reports in future.
Cycles Autosmooth option causes segfault when selectedto Autosmooth option causes segfault when selectedOki, see the issue now…
Autosmooth option causes segfault when selectedto Autosmooth option causes assert failure when selectedThis issue was referenced by blender/blender-addons-contrib@5a8d7af642
5a8d7af642
Closed by commit
5a8d7af642
