Smoke simulator memory leak with high poly mesh emitter #40115
Reference: blender/blender#40115
Windows 7 x64
Broken: Official Release
Worked: It appears to work with an older 2.69.3 build.
If you have a highly subdivided plane used as smoke emitter memory consumption will go up steadily even with a low res smoke domain. Also memory isn't freed when loading a new scene.
The attached .blend file has such a setup, just press Alt+A and check the memory usage. At frame 200 it's at around 3,5 gb on my system, at frame 300 at 5,2 gb and so on.
smokesim-subdivided-emitter-mesh.blend
Added subscriber: @KaiKostack-3
Added subscriber: @scorpion81
Hi,
i think i found the cause of this memoryleak. A copied derivedmesh was not freed after usage and copied again and again....
See the patch file for a (possible) fix.
scorpion81
Added subscriber: @mont29
Added subscriber: @miikah
Actually, own fault…
This issue was referenced by
355709432e
Closed by commit
355709432e
