Color circle values beyond max values. #40154
5 Participants
Reference: blender/blender#40154
Windows 64 bit, GT 740M
Broken: 2.70
The color circle allows values between one and zero, however if you use drag and select to increase all values at the same time, you can go beyond the max value. You can also get values less than zero.
Added subscriber: @UnknownFreak
Added subscriber: @SebastianRothlisberger
Can't recreate less than Zero.. Maximum limit does indeed not work with Multiselect.
To recreate the less than zero one, do the same thing, then put one of the channels back to zero, redo the multi select (select the channel with zero value last), and decrease.
Added subscribers: @ideasman42, @Sergey
Multibutton drag uses hard limits of the values, not soft ones.
@ideasman42, remember you've been working on similar issue. Mind checking on this as well?
If this also helps a little more, this bug seems to only work on color circles with alpha channels.
This issue was referenced by
9892f038ef
Closed by commit
9892f038ef
