Fluid simulation needs more memory than displayed #40203
5 Participants
Reference: blender/blender#40203
Windows 7 (64 bit with service pack 1)
Intel Core i7-2670QM @ 2.20GHz
16 GB RAM
NVIDIA GeForce GT540M
Broken: example: 2.70a (64bit)
Worked: unknown
The idea for the animation is for liquid metal to pour into a mold. The Fluid simulation estimated to use 7MB of RAM and when the mold obstacle is set to Volume then it calculates just fine.
Changing mold obstacle to Shell causes simulation to use all available RAM (16 GB) and if process not killed, crash the machine.
Open the attached .blend
Confirm Mold object is set to Shell
Select Gold domain
Press Bake.
Example of memory usage. As you can see the simulation has gone bezerk and used the entire 16 GB RAM. If left, my system eventually seizes up and a hard reset (i.e. power off) is required.
cc_test_3_-_broken.blend
Added subscriber: @AndrewButtery
Fluid simulation estimated to use 7MB of RAM. Changing obstacle to Shell causes simulation to use all available RAM (16 GB) and if process not killed, crash the machine.to Fluid simulation needs more memory than displayedAdded subscribers: @genscher, @Sergey
@genscher, can you please have a look?
but the thing is, it's not always possible to predict how much memory is gonna to be used by the external library. And blender can only predict memory it requests from the system. Because of the fragmentation physical memory usage might be much higher..
Added subscriber: @mont29
Added subscriber: @totoro-4
I can confirm this on Linux 64bit too. And the result is the same as "Shell" when the "Both" mode used. "Shell" mode runs away with the memory almost immediately but the "Volume" mode finishes quickly with low memory consumption (roughly 250 MB).
So, after some debugging, this memory allocation boom happens exactly in the cycle beginning at line 531 of elbeem/intern/ntl_geometryobject.cpp in function ntlGeometryObject::initMovingPoints(double time, gfxReal featureSize).
For VOLUMEINIT_VOLUME, the triangles.size() returns 64 here but for VOLUMEINIT_SHELL, it's 10364. I think this big number causes the large allocation in the cycle.
This function was called from line 1811 of elbeem/intern/solver_init.cpp. This call happens twice at the start of VOLUMEINIT_SHELL and only once at the start of VOLUMEINIT_VOLUME. The memory boom happens at the first call. I hope this helps to solve the problem.
That's fantastic Fazekas!
Thanks for spending the time to look into this one and also hope this helps the developers to find the problem...
Looks like real issue would be in elbeem then… Think will just add a warning about shell options (that they might induce huge mem consumption), and close that report (and we expect a brand new system for fluid simulations in coming months…).
Thanks for the report and nice investigation, in any case!
Also, note that mem usage annonced is the mem needed for the bake cache itself, not the mem needed to compute that cache.
This issue was referenced by
c4814c8764
Closed by commit
c4814c8764
