addObject() 'time' parameter inconsistent #40402
5 Participants
Reference: blender/blender#40402
Windows 7 64 bit, Nvidia GeForce GT540M Cuda
Never worked. (tested with 2.63 up to current Hash
7fb33e5
)Short description of error
The 'time' parameter of addObject() gives inconsistent results. Generally the added object lives longer as it should. With 'time' set to 1, the object lives 2 logic tics. With 'time' set to 10, for example, the object lives 13 logic tics.
Play the game. Check the messages in the System Console.
AddObject_life_bug.blend
Added subscriber: @raco
It probably has something to do with the built-in standard of 50fps for the Add Object Actuator. Notice in the example blend file that on the 6th tic, life shows 5.
Added subscriber: @Moguri
Yeah, the life/time parameter is a pseudo-second of sorts. It looks like it assumes 50fps, which is not very accurate:
If this is fixed to be actual seconds, it could break existing games. So, this probably isn't worth fixing. On the other hand, it is hard to be precise with the time parameter since it is based on framerate. If precision is an issue, you can always use the Python time module and KX_GameObject.endObject() to handle this yourself.
I don't really see how it would break existing games if the value would be determined by the logic tic rate.
It would alter the timing, which could throw off existing games.
Hi moguri,
Thanks for answering.
I think you're talking about the case where game developers purposely used other values to work around this limitation. For example, setting time to 50 so the object is removed after one second, even when the logic tic rate is 60.
If such a developer would like to run/export his (old) game with a Blender version without this limitation, indeed he would be forced to change time to 60. But if you ask me, I think he would gladly do so, because he'll never have to deal with this limitation ever again, when working on future projects.
I will ask people for their opinion on the Blender Artists Forum and keep you posted.
Thanks
I was thinking more off people you just played with the number until it "felt right." These people will have their games subtly changed. This may be a problem or it may not. Regardless, this won't be fixed for 2.71, since I don't want to introduce any potentially game breaking changes at this stage.
Also, if this is going to be changed, it will be changed to just use seconds, and not be framerate dependent.
Added subscriber: @AngusHollands-4
I feel that whilst this is a valid argument, there are already enough inconsistencies in the engine timing design as it is, and we should address them asap.
If it breaks existing games, it won't be difficult to alert users of the change. New users should find it simpler to use with seconds. I don't believe we should encourage "compatibility" with such bugs, especially when they aren't mainstream features (the life attribute of an object is rarely used by most blend files I've investigated).
Added subscriber: @brita
If we change over to seconds for this, some other (potentially breaking) changes would happen as a result:
I'm all for changing to seconds. You can read about opinions on BA: Your opinion about fixing the addObject 'time' parameter?
Maybe this could be changed from type 'Bug' to 'To do' or 'Design'. I think we all agree that changing to seconds is the best solution.
Agree on changing to seconds when we feel like breaking compatibility again (3.x?). Moved to the TODO . Thanks for the report.
