Creating Rigid Bodies is rejected for some meshes #40447
Reference: blender/blender#40447
Windows 8.1, Intel integrated graphics (Sandy bridge).
Broken: current master branch (
cc2cdfb0
)Short description of error
In engine "Blender Render", creating Rigid Bodies is rejected if the (base) Mesh Data object contains no faces, even if faces are created by the modifier stack (for example using the Screw modifier). Only using the "BASE" as mesh-source should be disallowed in this case, since using "FINAL" will yield a proper mesh.
Create a circle mesh without faces. Use the Screw modifier to create a torus, but don't apply it. Creating a Rigid Body from this object is not possible (message: "Can't create Rigid Body from mesh with no polygons").
Proposed fix
Remove the check from rigidbody_object.c, and possibly add it at a later stage in the pipeline (when it is clear what mesh the Rigid Body should really be based on).
diff --git a/source/blender/editors/physics/rigidbody_object.c b/source/blender/editors/physics/rigidbody_object.c
index e4426fd..8fb79f8 100644
- a/source/blender/editors/physics/rigidbody_object.c
+++ b/source/blender/editors/physics/rigidbody_object.c
@@ -100,10 +100,6 @@ bool ED_rigidbody_object_add(Scene *scene, Object *ob, int type, ReportList *rep
Added subscriber: @der_fab
I messed up the formatting of the diff.
Added subscriber: @LukasTonne
Agreed, this test is also pretty useless, since you can make a "proper" mesh with faces, make it a rigid body, then remove all faces afterward ... or assign different mesh datablock after making a rigid body object ... or something else, probably there are lots of ways to circumvent it.
This issue was referenced by
7674ebf340
Added subscriber: @mont29
Closed by commit
7674ebf340
