Game Engine returns NONE when accessing object's .groupMembers attribute #40778
Reference: blender/blender#40778
Windows 7
Broken: 2.7
19e627c
When trying to access the object attribute .groupMembers, NONE is always returned. Only way it works is if you instance the group and put it on an active layer and try to access the group instance's attribute.
Open the System Console and uncomment the print statements individually and run the Game Engine to see the bug. There are 4 different setups of accessing the attribute: 1.From object on Active layer. 2.From object on inactive layer 3.From group instance on active layer (This works currently). 4.From group instance on inactive layer.
BGE_bug.blend
Added subscriber: @BrianCochran
Added subscriber: @brita
Added subscribers: @kupoman, @Moguri
I see several things here. One, you are getting objects from the scene with both:
As far as I can tell, this is always getting the objects correctly including in the last case.
Then, having the object, you always query for groupMembers that, according to the documentation :
"Returns the list of group members if the object is a group object, otherwise None is returned."
So, doing this for the Cylinder and Cube is correctly returning None, as they belong to a group, but are not a group instance.
As I see it, this:
should do what you want in that case.
But it doesn't because groupObject is returning None. I don't think this even makes much sense as an object can belong to several groups, so this should return a list? @kupoman @Moguri
Summing up the problems:
KX_GameObject.groupObject is returning None when it should return the group
KX_GameObject.groupObject should actually return a list??
KX_GameObject.groupMembers is returning None when the group instance is on an invisible layer, should it?
related commit:
7beff06950
I think things are working as intended, but this is instead a case of confusing documentation. In the BGE, a KX_GroupObject is an object representing a dupligroup instance. So, only dupligroup instances will have a non-None groupMembers. Also, only objects that were instantiated from a dupligroup instance will have a non-None groupObject (in this sense, only one instance ever causes a specific object to be instantiated, so a list doesn't make sense). The only "groups" that the BGE cares about are dupligroup instances (it other wise doesn't recognize Blender groups).
Changing the documentation then.
This issue was referenced by 0eb272df755772c2ad01e3e3738377d08803dda9
7501bdc52e
