The new Ashikhmen Shirley shader; firefly explosion with very small lamps regardless of power. #40962
Reference: blender/blender#40962
Win7 64 bit, Ivy Bridge i7 CPU, ATI 7xxx GPU, 16 gigs of RAM
Broken:
b5982f7
Worked: Probably none.
The new Ashikhmen Shirley shader errors out and produces a massive number of bright fireflies when a small-sized lamp (such as a Sunlamp with size 0.01), is shown onto it. This occurs when it is selected for the normal glossy shader as well, but disappears when you increase the size of the lamp. I added a diffuse cube as a brightness reference to show that it is not due to the lamp's brightness that is causing it.
Open the attached .blend in a post 2.71 build and switch to the rendered view, now set the sunlamp size to something much larger and watch the problem disappear.
Cycles_fireflies.blend
Added subscriber: @Ace_Dragon
I forgot to add, this issue is limited to the Ashikhmen behavior only, Beckmann and GGX are unaffected when used in both shader node types.
This issue was referenced by
7bc87a372e
Closed by commit
7bc87a372e
