FBX export fails with some very simple material setups #41396
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#41396
Win7 Home premium 64 SP1, i7, Nvidia GTX675m
2.71 official
The FBX exporter gives an error when trying to export a mesh that is using some materials linked from other .blend files.
It's very easy to reproduce:
Added subscriber: @piiichan
Two example files : example_files.7z
One (lib_materials.blend) contains the 3 materials.
And the other (ref_materials.blend) has a cube that links to them. Try to export the cube to FBX, it won't work.
Added subscriber: @mont29
Added subscriber: @ideasman42
This issue was referenced by
07747bcf64
Closed by commit
07747bcf64
.I modified the line you committed
(https://developer.blender.org/rBA07747bcf64963eefaff8aaa9cee24ed652fda5b9)
in my export_fbx_bin.py.
And now my exported FBX models don't have the materials that are using nodes, is this normal ? (I'm still using Blender 2.71 official to test your change)
If that's normal, then I think it's not an acceptable solution at all.
The way I expect it to work is: my exported FBX models have all their materials, just like in Blender. Even node-based materials. If node-based materials can't be correctly "coded" in FBX, then just let them be default materials in the FBX file, so we can tweak/rebuild/code them in the target game engine/renderer. Right now I can't do anything, they're just gone.
Nodal materials were never supported at all. Bug was that they were still being tried, in this specific part of the code, when they should not.
I do not really see the point in exporting dummy data, if you have to re-create them in other app, you can as well re-create them from scratch…
And no, exporting nodal materials is not considered a TODO currently, it does not really makes sense anyway.
I do recreate them, but I can't necessarily be able to specify in other apps what parts of the mesh should have them applied, I use Blender for that.
I'm using the Unity game engine, it lets me do whatever I want with a material from an imported 3d model, like writing custom realtime shaders. But the sub-meshes Unity generates for an imported 3d model are per material, and this info is in the FBX file. If the material is not even present in the FBX file, I can't apply different materials to different parts of a mesh.
Node-based materials are very common in Blender nowadays. Does it mean that a mesh should have zero material if all of its materials are node-based ? It doesn't make sense to me... There should be default placeholder materials in the FBX file instead, meaning "There is a material here, we weren't able to correctly describe it in FBX's terms, but it should be there". With the current solution, 100% of the information is lost, even the name of the material, and the parts of the mesh it's applied to.
Anyway, I can work around it using a bit of scripting in Blender.
And thanks for the quick "fix" nevertheless :)
Oh… did not thought about the 'multimats per mesh' case :/
Will have a look at that, then.
Better fix in
e35de9d174
then! :)Now unexportable mats are still 'written' as default FBX materials, so they are usable as placeholders.
I copy/pasted your changes from https://developer.blender.org/rBAe35de9d174291adab3b28ba660962dc0b084d9d3 into my export_fbx_bin.py
I'm still in Blender 2.71, so I hope your changes are compatible with that version... (Replacing my whole file with the new one gave me errors on export)
I tried exporting 3d models (old and new) that are using nodal materials, and it looks like the FBX export is now working fine. I just get a default diffuse gray material in Unity in place of my nodal materials, which is just what I expect, excellent.
I'm just speaking for myself here, but I think this behavior is the most logical one. It's also the most conservative approach, which is better than a destructive one.
I found another issue: if I add a material slot to the mesh, but if I leave it empty (no material assigned to it), the export fails. See image below
Thanks, fixed in
3365561271
(own stupid mistake :/ ).This issue was referenced by 3f0687b8ad95e7fec6f1469389f08f5dd0915f32
