Cycles volume rendering is too dark #41473
Reference: blender/blender#41473
Windows 7 x64
Geforce GTX 780
Broken: 2.71.4
7c9b8aa
buildbotWorked: 2.71 release
A dense white scattering material is expected to reflect almost all light, but appears
very dark in recent buildbot builds. The results of the 2.71 release seem much
closer to the expected result.
Open the attached blend in a recent build, hit render.
Added subscriber: @erwin94
Attached file: volume_cycles_test.blend
Okay, I was a little bit too quick with reporting this...
The results are the same for both versions, if I manually set the volume light path bounces
to the same value. The question then is, why does it load the file with a bounce value of 0
in 2.71.4 and 1 for 2.71?
The default value for the bounce changed by @ThomasDinges, but i wouldn't expect the existing files to be changed.
Will check on making existing files to not change the final render result.
This is a limitation of Python properties as far as I know. The default was "1", if you never changed that yourself, it won't be saved into the blend file. So now it takes the new default which is 0. We had the same issue between 2.69 and 2.70, when we changed default bounces. See http://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.70/Cycles "Backward compatibility breakage"
Ah, okay. If fixing this is difficult I'm fine with closing this bug.
For any somewhat complex volumetric rendering scene I expect that value
has been touched, and I only found this in a simple test scene.
So I think accepting this breakage might be okay, but should
have a note in the release notes again.
This issue was referenced by
21a7433faa
Closed by commit
21a7433faa
