Compositing reroute converts floats to red color #41573
5 Participants
Reference: blender/blender#41573
Ubuntu 14.04
GTX 660M
Broken: 2.71.5
ca1bca4
Worked: 2.71
When viewing a float reroute node, instead of converting the value to RGB, only the red canal is set, resulting in red image.
Viewer connected to the RenderLayer alpha output:
Viewer connected to the reroute output:
bug_reroute.blend
Added subscriber: @pioverfour
#41724 was marked as duplicate of this issue
Added subscribers: @LukasTonne, @Sergey
@LukasTonne, mind having a look?
Added subscriber: @mont29
Added subscriber: @sebastian_k
◀ Merged tasks: #41724.
Ok, so issue goes back (at least) to
09874df135
It affects both reroute and muted nodes (try e.g. a NOP math node between alpha input and viewer, no problem, but mute it, you get red again).
This simple patch fixes it all, but would not swear this is the right solution, since I do not exactly fully understand that 'convert' parameter…
P140: (An Untitled Masterwork)
Lukas, definitively your call now. ;)
@mont29 the
use_conversion
parameter for proxies controls whether data gets converted to the proxies own type in every case or not. This is useful e.g. for node groups, where you expect the proxies to have the specified interface type. So for example when a group socket is defined as "Float" and an RGBA is passed in it always gets converted to Float anyway, even when used as RGBA internally. Otherwise the behavior of the group could vary depending on the external nodes.For the reroute sockets a conversion should not be necessary - in fact they change their type in the UI to indicate that the input type is passed on unmodified! The problem then is why the reroute node actually causes the buffer to become an "RGBA" (with only the red channel). The viewer node should only see a Float input and use the first (R) channel as the value, instead of interpreting it as a full RGBA color value ...
@LukasTonne imho, issue is that there is no conversion here, precisely.
Placing prints in
NodeOperationBuilder::add_datatype_conversions()
, for this file I got the following:So imho, either we use conversions for reroute/mute proxies too, or we change that part of
:to:
So that if an operation at one point of the link requires conversion, we do it, even if the other does not require it.
Sounds good
This issue was referenced by
876ccc8373
Closed by commit
876ccc8373
