Won't open blend files with non-Latin charasters in the name #41629
Closed
opened 2014-08-29 12:16:53 +02:00 by Mikhail Rachinskiy · 13 comments
Windows 8.1 x64
Renderer: GeForce GTX 860M/PCIe/SSE2
Vendor: NVIDIA Corporation
Version: 4.4.0
Broken: 2.71.5 e2c412f
New builds failed to open by double clicking associated blend files with non-Latin charasters in the name of these files.
File -> Open is working.
  • Unzip and open attached blend file by double clicking non_latin.7z, if failed you should see a default startup scene
  • Now open the same file by File -> Open, should always work
GIF animation to illustrate the issue:
**System Information** Windows 8.1 x64 Renderer: GeForce GTX 860M/PCIe/SSE2 Vendor: NVIDIA Corporation Version: 4.4.0 **Blender Version** Broken: 2.71.5 e2c412f **Short description of error** New builds failed to open by double clicking associated blend files with non-Latin charasters in the name of these files. File -> Open is working. **Exact steps for others to reproduce the error** - Unzip and open attached blend file by double clicking [non_latin.7z](https://archive.blender.org/developer/F107268/non_latin.7z), if failed you should see a default startup scene - Now open the same file by File -> Open, should always work GIF animation to illustrate the issue: ![Untitled.gif](https://archive.blender.org/developer/F107269/Untitled.gif)
Author
Member
Author
Member
Added subscriber: @MikhailRachinskiy
Sergey Sharybin was assigned by Bastien Montagne 2014-08-29 12:25:00 +02:00
Added subscriber: @mont29
Sergey, I would suspect this could be due to new 'launcher' helper on win platform?
Could be but i can't reproduce the issue here.
Are there any error messages in the console?
Could be but i can't reproduce the issue here. Are there any error messages in the console?
Author
Member
Yeah, this could be Windows issue because I do not have Russian locale installed
Yeah, this could be Windows issue because I do not have Russian locale installed ![27.png](https://archive.blender.org/developer/F107281/27.png)
Iv'e just committed a bit related change, which fixes issue with blender.exe -r registering blender-app.exe as the handler for .bend files (cb7d430).
For your thing i'm not really sure, did you type it manually to the console? I'm not really sure why you've got ? instead of actual letters.
Also, does the same issue currently happens with 2.71 official release?
Iv'e just committed a bit related change, which fixes issue with `blender.exe -r` registering `blender-app.exe` as the handler for .bend files (cb7d430). For your thing i'm not really sure, did you type it manually to the console? I'm not really sure why you've got ? instead of actual letters. Also, does the same issue currently happens with 2.71 official release?
Author
Member
Yes I typed it manually, guess it was silly move.
2.71 release is working, and if I will replace "blender.exe" on "blender-app.exe" in the Windows registry it would actually work! Thanks!
I think that "blender.exe" is no longer default executable file for the Windows platform should be announced/described somewhere, because some people like myself who are using ZIP archives instead of install packages will continue to associate their blend files with old "blender.exe", which would lead them to this problem.
Yes I typed it manually, guess it was silly move. 2.71 release is working, and if I will replace "blender.exe" on "blender-app.exe" in the Windows registry it would actually work! Thanks! I think that "blender.exe" is no longer default executable file for the Windows platform should be announced/described somewhere, because some people like myself who are using ZIP archives instead of install packages will continue to associate their blend files with old "blender.exe", which would lead them to this problem.
The thing is, you should use blender.exe, not blender-app.exe.
I need to know exact circumstances in which blender-app.exe loads file nicely and blender.exe does not.
The thing is, you should use blender.exe, not blender-app.exe. I need to know exact circumstances in which blender-app.exe loads file nicely and blender.exe does not.
Author
Member
Associated with blender.exe
HKEY_CLASSES_ROOT\Applications\blender.exe\shell\open\command
Key: (Default)
Value: "C:\Users\Mikhail\Downloads\b\blender.exe" "%1" - no difference if I change this to blender-app.exe manuallyHKEY_CLASSES_ROOT\blend_auto_file\shell\open\commandKey: (Default)
Value: "C:\Users\Mikhail\Downloads\b\blender.exe" "%1" - starts to work if I change this to blender-app.exe manually
Associated with blender-app.exe
HKEY_CLASSES_ROOT\Applications\blender-app.exe\shell\open\command
Key: (Default)
Value: "C:\Users\Mikhail\Downloads\b\blender-app.exe" "%1" - works as isHKEY_CLASSES_ROOT\blend_auto_file\shell\open\command**- entry not created**
Associated with blender.exe HKEY_CLASSES_ROOT\Applications\blender.exe\shell\open\command **Key:** (Default) **Value:** "C:\Users\Mikhail\Downloads\b\blender.exe" "%1" **- no difference if I change this to blender-app.exe manually**HKEY_CLASSES_ROOT\blend_auto_file\shell\open\command**Key:** (Default) **Value:** "C:\Users\Mikhail\Downloads\b\blender.exe" "%1" **- starts to work if I change this to blender-app.exe manually** ----------------------------- Associated with blender-app.exe HKEY_CLASSES_ROOT\Applications\blender-app.exe\shell\open\command **Key:** (Default) **Value:** "C:\Users\Mikhail\Downloads\b\blender-app.exe" "%1" **- works as is**HKEY_CLASSES_ROOT\blend_auto_file\shell\open\command**- entry not created** -----------------------------
This issue was referenced by 526ae635d1
This issue was referenced by 526ae635d191d0245fc2c0923130ed968891d6a0
Closed by commit 526ae635d1.
Reference: blender/blender#41629
