FBX (binary) exporter does not export actions with one frame animations #41766
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#41766
Windows 7 Professional 64Bit
Broken: 1.71
Hello there,
i recently stumbled uppon a small bug in the FBX-exporter for the binary format. The exporter will not export an action if the animation has no changes during its animation, for example if the action has only one frame. I also tried to work arround the problem by copy-pasting the keyframe over two or multiple frames but the exporter still cuts the animation, as long as i do not have at least one change in the animation.
For reference, the old ASCII-exporter exports these animations, so it would be nice if the binary exporter would too.
Best Regards,
Wilke
Added subscriber: @S_Wilke
Yes, currently we optimize things during anim export.
In fact, I’m seriously thinking to make this optional behavior, for another reason too - it looks some apps like UE4 have issues with armatures having some bones animated and others not. :/
Hmmm, actually, rechecked the code, and we do write single-key actions, except for the 'global scene' one.
Please check with a build from our buildbot, 2.71 version of the addon is rather old!
i checked it with 2.71-6 (blender-2.71-5202fca-win64) and it still does not export one frame animations. They do not appear in U4 and with notepad++ i found no trace of the animation name "BasePose" or "Block"
BUT i realised also an aditional bug in the animation that ties in with the wrong armature rotation problem:
In some animations where the left arm is not animated (in nearly every "slash"-animation, for example SlashL1A, SlashL1B etc.) it has the "block"-pose that was never exported.
I tested it with the night-build and the official stable, both version have this behaviour
i attached the blend file and the fbx export file with it:
ExportTest271-6.fbx - FBX nightly build blender-2.71-5202fca-win64
ExportTestStable.fbx - FBX stable 2.71
Manequin_Test_X2.blend - Blend-File
This issue was referenced by
f7ef101d09
Closed by commit
f7ef101d09
.Ok, just committed a fix to the first issue (note it will make exported files significantly bigger… But better too much than too few here I guess).
Other things in your last comment are an issue specific (afaik) to UE4, which ignores 'rest' pose of 'bones' (~joints, in fact) when applying animation to them. I’m still not sure whether this is a bug from their side our Blender side (yet, Unity handles those cases perfectly), so I made a report about it on their site (see also #41719).
So consider this report as fixed, will add you as followers of #41719 for the remaining issues.
