FBX exporter causes crashes in other software when smoothing groups are active. #41922
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#41922
Windows 7, AMD 7870 graphics card, AMD FX6300 processor, 16gb RAM, 500GB hard-disk.
Broken: 2.71.6 (2.72 test version)
I am trying to export Skeletal meshes with blend-shapes out of Blender and into Unreal Engine 4.4.1. I noticed that the FBX file produced in the latest test version of Blender was causing UE4 to crash under certain circumstance, and therefore produced as simple a file as possible (a sphere with a skeleton and a couple of squash-stretch variations for blend-shapes). One area that I have immediately noted is that the smoothing (now defaulted as 'None' in the export options - which suggests that the developers may well be aware of the issue), when set to 'Edge' or 'Face' will create a file which neither Unreal, nor Autodesk's FBX converter want to touch (the latter coming up with the 'Not enough parameters' error).
SuperSimple272.blend
14.Try opening these files in Unreal and/or FBX converter 2013. The first will open fine, animate and deform fine, but give a warning about lacking smoothing groups when imported into Unreal (and therefore look a bit mushy in the editor). The second will crash Unreal and fail to be converted into a FBX 2013 ASCII file in the converter (so I can't even read it to work out what is going wrong).
Thank you so much to the Developers for their continued efforts to improve the FBX format: it really is massively, massively appreciated for game developers with Zero budget. I dislike pointing out the failings in your work, but only hope that highlighting these niggles while the software is in it's infancy, will boost its expected excellence when it launches proper. I look forward to the day when god-awful cut down software for dummies, like Maya LT, will no longer be the only option for the Indie game developer of distinction.
I hope that you can fix this, and make the FBX Exporter truly awesome.
Thanks alot.
Added subscriber: @burningGiraffe
Sorry, just downloaded my own sample, and I seem to have lost the armature animation. Try this one instead:
SuperSimple272_2.blend
Will check that. Not though that if smooth face/edge were set to None by default, it's because they tend to conflict with exported split normals, which are more precise and universal.
This issue was referenced by
3d5cd1956e
Fixed the crash cause in master.
Please note though:
Closed by commit
3d5cd1956e
