Array Modifier "Merge" bug? #41983
Closed
opened 2014-09-28 03:21:27 +02:00 by Admiral Potato · 21 comments
Windows 7 Ultimate, 64 bit, GTX 680
Windows 8 pro, GTX 780ti
Broken: 2.72 RC1
Worked: 2.71
It seems that the Array modifier's "Merge" feature is no longer correctly. It seems to skip over connecting every other generated copy?
In the attached .blend file, take a look at the top of this Octopus in both 2.71 and 2.72. The effect of the breakage seems to be exaggerated when using "alt-a" to play back the animation in an OpenGL shading mode.
volume_octopus3_bugreport.blend
(simple example of bug array_mod.blend)
**System Information** Windows 7 Ultimate, 64 bit, GTX 680 Windows 8 pro, GTX 780ti **Blender Version** Broken: 2.72 RC1 Worked: 2.71 **Short description of error** It seems that the Array modifier's "Merge" feature is no longer correctly. It seems to skip over connecting every other generated copy? **Exact steps for others to reproduce the error** In the attached .blend file, take a look at the top of this Octopus in both 2.71 and 2.72. The effect of the breakage seems to be exaggerated when using "alt-a" to play back the animation in an OpenGL shading mode. ![8-adaptive_256-diff_100.gif](https://archive.blender.org/developer/F113275/8-adaptive_256-diff_100.gif) [volume_octopus3_bugreport.blend](https://archive.blender.org/developer/F113274/volume_octopus3_bugreport.blend) (simple example of bug [array_mod.blend](https://archive.blender.org/developer/F114106/array_mod.blend))
Author
Author
Added subscriber: @AdmiralPotato
#42031 was marked as duplicate of this issue
Added subscriber: @mont29
Bastien Montagne self-assigned this 2014-09-28 08:47:06 +02:00
Added subscriber: @ideasman42
Gah, this behavior was intended, from comments in code. Yet, I really see no good reason for it - if it’s the idea that this could end in merging vertices that are farther than threshold distance (neighbor-from-neighbor additive 'error'), it’s way less painful than bug reported here imho.
Campbell, really need your advice here, this simple patch fixes the bug, do you see any issue with it?
P149: (An Untitled Masterwork)
diff --git a/source/blender/modifiers/intern/MOD_array.c b/source/blender/modifiers/intern/MOD_array.c
index 6679648..d338ac0 100644
--- a/source/blender/modifiers/intern/MOD_array.c
+++ b/source/blender/modifiers/intern/MOD_array.c
@@ -606,11 +606,6 @@ static DerivedMesh *arrayModifier_doArray(
 					int target = full_doubles_map[prev_chunk_index];
 					if (target != -1) {
 						target += chunk_nverts; /* translate mapping */
-						/* The rule here is to not follow mapping to chunk N-2, which could be too far
-						 * so if target vertex was itself mapped, then this vertex is not mapped */
-						if (full_doubles_map[target] != -1) {
-							target = -1;
 					full_doubles_map[this_chunk_index] = target;
@@ -624,7 +619,7 @@ static DerivedMesh *arrayModifier_doArray(
 				        c * chunk_nverts,
 				        chunk_nverts,
 				        amd->merge_dist,
-				        false);
+				        true);
@@ -644,7 +639,7 @@ static DerivedMesh *arrayModifier_doArray(
 		        first_chunk_start,
 		        first_chunk_nverts,
 		        amd->merge_dist,
-		        false);
+		        true);
 	/* start capping */
@@ -669,7 +664,7 @@ static DerivedMesh *arrayModifier_doArray(
 			        start_cap_start,
 			        start_cap_nverts,
 			        amd->merge_dist,
-			        false);
+			        true);
@@ -694,7 +689,7 @@ static DerivedMesh *arrayModifier_doArray(
 			        end_cap_start,
 			        end_cap_nverts,
 			        amd->merge_dist,
-			        false);
+			        true);
 	/* done capping */
@@ -711,7 +706,12 @@ static DerivedMesh *arrayModifier_doArray(
 	if (use_merge) {
 		for (i = 0; i < result_nverts; i++) {
 			if (full_doubles_map- [x] != -1) {
-				tot_doubles++;
+				if (i == full_doubles_map[i]) {
+					full_doubles_map- [x] = -1;
+				else {
+					tot_doubles++;
 		if (tot_doubles > 0) {
Gah, this behavior was intended, from comments in code. Yet, I really see no good reason for it - if it’s the idea that this could end in merging vertices that are farther than threshold distance (neighbor-from-neighbor additive 'error'), it’s way less painful than bug reported here imho. Campbell, really need your advice here, this simple patch fixes the bug, do you see any issue with it? [P149: (An Untitled Masterwork)](https://archive.blender.org/developer/P149.txt) ``` diff --git a/source/blender/modifiers/intern/MOD_array.c b/source/blender/modifiers/intern/MOD_array.c index 6679648..d338ac0 100644 --- a/source/blender/modifiers/intern/MOD_array.c +++ b/source/blender/modifiers/intern/MOD_array.c @@ -606,11 +606,6 @@ static DerivedMesh *arrayModifier_doArray( int target = full_doubles_map[prev_chunk_index]; if (target != -1) { target += chunk_nverts; /* translate mapping */ - /* The rule here is to not follow mapping to chunk N-2, which could be too far - * so if target vertex was itself mapped, then this vertex is not mapped */ - if (full_doubles_map[target] != -1) { - target = -1; - } } full_doubles_map[this_chunk_index] = target; } @@ -624,7 +619,7 @@ static DerivedMesh *arrayModifier_doArray( c * chunk_nverts, chunk_nverts, amd->merge_dist, - false); + true); } } } @@ -644,7 +639,7 @@ static DerivedMesh *arrayModifier_doArray( first_chunk_start, first_chunk_nverts, amd->merge_dist, - false); + true); } /* start capping */ @@ -669,7 +664,7 @@ static DerivedMesh *arrayModifier_doArray( start_cap_start, start_cap_nverts, amd->merge_dist, - false); + true); } } @@ -694,7 +689,7 @@ static DerivedMesh *arrayModifier_doArray( end_cap_start, end_cap_nverts, amd->merge_dist, - false); + true); } } /* done capping */ @@ -711,7 +706,12 @@ static DerivedMesh *arrayModifier_doArray( if (use_merge) { for (i = 0; i < result_nverts; i++) { if (full_doubles_map- [x] != -1) { - tot_doubles++; + if (i == full_doubles_map[i]) { + full_doubles_map- [x] = -1; + } + else { + tot_doubles++; + } } } if (tot_doubles > 0) { ```
Added subscriber: @Idlero
Think this needs the regression tag, in fact :|
Added subscriber: @igvalor2
So... Will the issue be resolved?
This comment was removed by @ideasman42
*This comment was removed by @ideasman42*
This issue was referenced by 4c43fcf791
This issue was referenced by 4c43fcf791c3c26fe5f729ffe5e96bae2957e88a
Closed by commit 4c43fcf791.
This issue was referenced by 561b52b356
This issue was referenced by 561b52b3562ab4e580d67cb228bd0515427af6ef
Author
Changed status from 'Resolved' to: 'Open'
Author
Sadly, when I opened the blend file that I attached to this bug report with the newly released 2.72, I still had a similar but slightly different issue when animating. It now looks like the modifier is trying to find the very first vertex in the mesh, and merge all of the radially merged verts with that one, but only every other frame of animation. Would you please take a look at the previously attached blend file once more, and press alt-a to start animating it? That's where the problem persists.
See attached animated GIF for an example.
Sadly, when I opened the blend file that I attached to this bug report with the newly released 2.72, I still had a similar but slightly different issue when animating. It now looks like the modifier is trying to find the very first vertex in the mesh, and merge all of the radially merged verts with that one, but only every other frame of animation. Would you please take a look at the previously attached blend file once more, and press alt-a to start animating it? That's where the problem persists. See attached animated GIF for an example. ![b0rken_at_272_realease.gif](https://archive.blender.org/developer/F115155/b0rken_at_272_realease.gif)
This issue was referenced by 1dd428ff6d
This issue was referenced by 1dd428ff6d45194fcabe1bdff62ede08f531a4ea
Closed by commit 1dd428ff6d.
This issue was referenced by 4c4c772496
This issue was referenced by 4c4c7724966e779e5879a721c1f663088c775c3f
6 Participants
Reference: blender/blender#41983
