Export dae crashes with un-applied modifiers using sl+open sim static export setting #42022
Reference: blender/blender#42022
system-info.txt
system-info.txt
Broken: 2.71
Worked:
When attempting to export as a dae with two mesh objects on separate layers, each mesh having an un-applied Modifiers, using the sl+open sim static setting and selecting only one mesh object blender crashes consistently each time. If the Modifiers are applied then it does not crash when exporting a dae.
small_pumpkin_Bug_Issue.blend
Added subscriber: @Tomi27
I tested this a bit more and found out that "Restrict Viewport selection" was toggled off in the Outliner. It exports normally with it on.
Added subscriber: @mont29
Gaia, care to check this one? thanks? :)
This issue was referenced by
c0276251d2
Closed by commit
c0276251d2
.Thanks for reporting.
Please note: The exporter only exports selected Objects which are also visible in the 3D Viewport. In your case the only selected Object was in a hidden layer. This resulted in an error during export.
I have fixed this now such that you get a warning about "no objects in export set" when you try to export Selected objects while none of the selected objects is visible.in the Viewport.
19d4d059f1
