FBX Export -> Unity Import #42029
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#42029
Win 7
Broken: Blender 2.72 RC
I have black faces when i put a blender file into my Unity project with shape keys.
So i tried to export it as an fbx manually. After that the black faces are gone, but the vertex groups does not work anymore. And the armature has not the same orientation as the mesh.
is it a bug or do i have to update the original unity import script?
Added subscriber: @TRuoss
Added subscriber: @mont29
Please do not report about (nor, preferably, use) Unity script, it’s using old exporter - and not a really good idea anyway to hide complex task behind a frontend like that.
For the remaining part of your report, I quite obviously need at least the .blend file, preferably together with the exported .fbx
And fyi, afaik FBX never supported vgroups per-se, they are only used through bones/shapes binding process…
ok good to know. here are the files
w_gen1_basemesh_v02.blend
w_gen1_shapekeys_v04.fbx
i use unity 4.5.4f1 if this info is needed
This issue was referenced by
34998c87c0
Closed by commit
34998c87c0
.Ok, so, armature issue was due to the fact you only used a modifier (usually, when you parent a mesh to armature, it also becomes the children of the arm object). Fixed in master now.
Your shape keys are here and working, but using FBX shapekeys on Unity is rather hairy process, please have a look at their doc
thx Bastien for the super fast replay, awesome job! i think something went wrong when i appended an other mesh to transfer the shape keys on my side. So i´m not sure it is a blender bug.
