Mirrored objects render black with Blender Internal #44102
5 Participants
Reference: blender/blender#44102
Occurs on 2 systems (both Windows 8.1). One system has a Geforce GTX745 card, and the other has an Intel integrated HD 4600 graphics.
Broken: Bug occurs on 2.73a and 2.74RC2
Worked: works on 2.69
When a duplicated mesh object has been mirrored (with the object shading is set to smooth and auto-smooth enabled), the Blender Internal renderer renders the object completely black.
The original object renders normally, but the duplicate renders as black. Even if the original object is deleted, and then the normals are recalculated on the second (remaining) object, it still renders as black. This bug appears to have similar symptoms as #40014 and #41079, which were previously fixed.
test.blend
Added subscriber: @AaronCorey
I should also mention that I discovered a work-around for this issue. If you make the duplicate object single-user and then apply the scale (Object > Apply > Scale), the object will then render properly. But of course, you lose the benefit of linked duplicates if you do that. I assume that applying the scale works because mirroring the object is essentially the same as scaling it by -1 along an axis?
Added subscribers: @mont29, @JulianEisel
Can confirm this. Turning off "Auto Smooth" or scaling by -1/mirroring again "solves" it. It also happens for every other object with a scale < 0 [Edit: and Auto Smooth enabled]. I bet Auto Smooth doesn't like negative scales... @mont29, maybe you can have a look? Might even be related to you custom normals work.
Added subscriber: @ideasman42
Caused by
776f8d5a6f
, assigning to @mont29I did a little more testing to narrow down the version where the change occurred. 2.70a renders mirrored objects correctly, but 2.71 renders them black.
This issue was referenced by
4685092fd8
Closed by commit
4685092fd8
.This issue was referenced by
c7dc142c1b
