Error: Not freed memory blocks #44127
6 Participants
Reference: blender/blender#44127
Windows XP/SP3 32Bits
Broken: version 2.74 (sub 2), branch b'master', commit date b'2015-03-24' b'21:33', hash b'87cff57', b'Release'
Worked: unknown
Error: Not freed memory blocks: 4, total unfreed memory 0.002144 MB
1.Run blender
2.Quit blender
An error was recorded when I output console log in a file.
Added subscriber: @sindra1961
I ran blender with a flag of debug-all, but the error is not recorded elsewhere.
result.txt
This comment was removed by @sindra1961
Added subscriber: @Sergey
Can not confirm the issue.
Does it happen when running blender with
--factory-startup
command line argument? What doesblender --debug-memory
output looks like?Your indication is wrong.
Some processing is not carried out if I add factory-startup argument.
If there is a cause there, the phenomenon does not happen.
The error message is not surely output when I run blender with the argument which you ordered.
However, it reappears when I run blender after deleting startup.blend.
In addition, I run blender after deleting startup.blend and make startup.blend.
Then it reappears even if I run blender again.
Take back words.
The indication is not wrong and in this case is inappropriate.
However, it is a fact that the outbreak point of the cause was limited thanks to the instructions.
I attach an error when I ran blender with debug-memory argument.
It does not reappear when I run blender with factory-startup argument, but reproduces it when I run blender in the state that there is not startup.blend.
I cannot reproduce here either. Can you please attach here your
userpref.blend
file (should be next tostartup.blend
one).This comment was removed by @sindra1961
I found a method to produce an error surely.
1.You delete startup.blend and userpref.blend and run blender.
2.You open the user prefs.
3.You turn on dynamic spacebar menu of addon.
4.You set international fonts in ON and choose one of translate.
5.You save user prefs.
6.You finish blender.
An error should be recorded in the log output.
result.txt
The log output when I set a series of setting after I started blender and carried out factory settings.
result.txt
I confirmed that it reappeared in 2.74RC4.
I attach userpref.blend which I made by confirmation work.
userpref.blend
I attach the log file.
result.txt
blender-2.74-rc4-windows32.zip
version 2.74 (sub 0), branch b'master', commit date b'2015-03-26' b'16:12', hash b'3593082', b'Release'
There was a report like this before.
#30271
However, it was closed for the reason of not being able to reappear.
I do not know whether the cause of that report is the same as this.
Added subscriber: @SatoshiYamasaki
Confirmed with blender 2.74RC4 in Windows8.1Pro x64.
Is this a problem related Japanese (or Asian multibyte) Windows? hmm...
Added subscriber: @ideasman42
Issue is “simply” that
app_translations_free()
is not called when leaving Blender, once you enable that 'space_bar' addon…Why this happens is pitch black mystery to me, currently… Campbell, you may have an idea?
This issue was referenced by blender/blender-addons@5d4cd5ae50
Closed by commit blender/blender-addons@5d4cd5ae50.
Changed status from 'Resolved' to: 'Open'
Added subscriber: @mont29
@mont29, Python isn't totally reliable here, Python isn't 100% sure to free all PyObject's on exit.
Would be better to call from
BPY_python_end
, similar tobpy_intern_string_exit
and others, See P216Re-opening.
I think that it was good that a cause becomes clear.
I hope that it is revised so that influence is not given elsewhere.
I intend to give the words of thanks if I confirm that a problem was improved.
@mont29
What you revised only deleted the nonsense line from py file.
The phenomenon does not reappear in it, but it is surely only symptomatic therapy.
Why do you not improve it to identify a cause?
I think that this cause only occurs because settlement is incomplete.
I think that it is natural for a problem not to occur even if you do not delete the line.
@sindra1961, the cause is known, P216 should fix it.
@ideasman42 , thanks. I agree with you.
Fixed as
f7dbce9914
.@mont29, @ideasman42:
I confirmed that a problem did not recur even if I added "from bpy import *" to space_view3d_spacebar_menu.py in the latest edition.
Thank you.
