Quickime/OSX: render output path with diacritic signs produces no video file #45165
Closed
opened 2015-06-23 23:40:35 +02:00 by Kris Slazinski · 10 comments
OSX 10.10.3, NVIDIA GeForce 320M 256 MB
Broken: 2.75 RC1 bff8b5d
When you try to render animation and set render output path with diacritic signs, Blender is rendering the video frame by frame, notifies that it's finished work, but in the end it produces no video file.
  1. Open attached blend file anim.blend
  2. render output path is set to "//renderó/" (ó is an example of diacritic sign in Polish language)
  3. Render animation using Animation button or Ctrl F12
  4. In the //renderó/ folder you end up with no file in the end.
  5. Change output path from "*renderó/" to "*render/"
  6. Render again.
  7. Now everything works and you end up with video file.
Maybe something changed about Blender's language coding? It's not UTF-8 anymore?
**System Information** Operating system and graphics card OSX 10.10.3, NVIDIA GeForce 320M 256 MB **Blender Version** Broken: 2.75 RC1 bff8b5d **Short description of error** When you try to render animation and set render output path with diacritic signs, Blender is rendering the video frame by frame, notifies that it's finished work, but in the end it produces no video file. **Exact steps for others to reproduce the error** 1. Open attached blend file [anim.blend](https://archive.blender.org/developer/F196998/anim.blend) 2. render output path is set to "//renderó/" (ó is an example of diacritic sign in Polish language) 3. Render animation using Animation button or Ctrl F12 4. In the //renderó/ folder you end up with no file in the end. 5. Change output path from "*renderó/" to "*render/" 6. Render again. 7. Now everything works and you end up with video file. Maybe something changed about Blender's language coding? It's not UTF-8 anymore?
Author
Author
Added subscriber: @mallow
Added subscribers: @Sergey, @mont29
jens verwiebe was assigned by Bastien Montagne 2015-06-27 16:03:28 +02:00
Works here on Linux…
Jens, not sure if you still handle issues on that platform? Else please reassign to @sergey.
Works here on Linux… Jens, not sure if you still handle issues on that platform? Else please reassign to @sergey.
Added subscriber: @MartijnBerger
Actually, it’s Martijn now our OSX maintainer ;)
jens verwiebe removed their assignment 2015-09-08 20:25:41 +02:00
Martijn Berger was assigned by jens verwiebe 2015-09-08 20:30:07 +02:00
Added subscriber: @ideasman42
Confirmed this on OSX 10.9.5
Note that unlike win32, OSX path/encoding is the same as Linux/BSD's (From Blender's code-side at least).
This problem us only happening with Quicktime exported movies.
Checked on the code qtkit_export.m and possible causes are:
381 ┊▒▒▒┊▒▒▒qtexport->filename = [[NSString alloc] initWithCString:name
382 ┊▒▒▒┊▒▒▒ encoding:[NSString defaultCStringEncoding]];
Looking at the docs, defaultCStringEncoding is discouraged:
https:*developer.apple.com/library/mac/documentation/Cocoa/Reference/Foundation/Classes/NSString_Class/index.html#*apple_ref/occ/clm/NSString/defaultCStringEncoding
You might sometimes need to use this encoding when interpreting user documents with unknown encodings, in the absence of other hints, but in general this encoding should be used rarely, if at all.
However this is tricky, In Blender all object names are utf8, but paths are an exception, where non utf8 latin1 characters are allowed too.
Even so, it may be best to use UTF8 (NSUTF8StringEncoding) here, since this is what blender uses for all input.
Confirmed this on OSX 10.9.5 Note that unlike win32, OSX path/encoding is the same as Linux/BSD's (From Blender's code-side at least). ---- This problem us only happening with Quicktime exported movies. Checked on the code `qtkit_export.m` and possible causes are: `381 ┊▒▒▒┊▒▒▒qtexport->filename = [[NSString alloc] initWithCString:name` `382 ┊▒▒▒┊▒▒▒ encoding:[NSString defaultCStringEncoding]];` Looking at the docs, `defaultCStringEncoding` is discouraged: https:*developer.apple.com/library/mac/documentation/Cocoa/Reference/Foundation/Classes/NSString_Class/index.html#*apple_ref/occ/clm/NSString/defaultCStringEncoding > You might sometimes need to use this encoding when interpreting user documents with unknown encodings, in the absence of other hints, but in general this encoding should be used rarely, if at all. ---- However this is tricky, In Blender all object names are utf8, but paths are an exception, where non utf8 latin1 characters are allowed too. Even so, it may be best to use UTF8 (`NSUTF8StringEncoding`) here, since this is what blender uses for all input.
Campbell Barton changed title from render output path with diacritic signs produces no video file to Quickime/OSX: render output path with diacritic signs produces no video file 2015-09-11 13:03:46 +02:00
This issue was referenced by 21826af5f7
This issue was referenced by 21826af5f730e7dff441d206b25d5ccd0992dea4
Member
5 Participants
Reference: blender/blender#45165
