Using Min Max of the Mapping node and texture extrapolation #45557
2 Participants
Reference: blender/blender#45557
Windows 7 Ultimate x64
Broken: 2.75
When using the Min Max of the mapping node, if the texture has not alpha on boundaries, the extrapolation of the color is weird.
There are 2 blend files, one with a texture where the top is alpha but not the bottom : http:*www.pasteall.org/blend/37266 and the 2nd blend has the same texture but with a row of one pixel of alpha at the bottom and then, it works as expected : http:*www.pasteall.org/blend/37267
Just go in Rendered mode to see differences.
Added subscriber: @EmmanuelLORANT
Added subscriber: @Sergey
This isn't a bug in the mapping node, it does exactly what you're asking to do -- it clamps coordinates to 0..1 range, making it behave like Extend texture mapping when texture is being extended across it's edge when texture coordinate is outside of 0..1 range. Only issue with that is that due to linear intepolation setting and texture being used as Repeat extension type it blends edge with the warped coordinate.
What you might do instead is to use Clip extension type of the image texture which was just added to Cycles (see
f296259
) and disable min/max setting in the mapping node.So thanks for the report, it is now possible to achieve effect you want with the next upcoming nightly build.
