Undo stack, after executing Macro, has wrong properties disabled #45825
Closed
opened 2015-08-17 16:10:50 +02:00 by Jose Conseco · 7 comments
In attached blend file I do simple macro (simple_operator):
  • subdivide mesh (in edit mode)
  • perform cut with knife tool, by user
  • deselect all.
    macroUndoStackBroken.blend - blend file with macro
    Now, I know knife tool dosen't support undo, so it is greyed out in F6 panel, after executing this script and calling operator. But undo stack order is reversed from what I see.
    What I mean is, operations performed by macro, after knife_tool, should have available undo properties, but they are disabled. What blender does is, it enables F6 properties, for operations performed before knife. This makes no sense, because as soon as you change property of operator performed before knife, knife operation gets cancelled, and everything after that gets canceled too. So you loose all operations performed after knife operation.
    How undo stack should work for macro is:
  • all F6 properties for operations performed before knife should be disabled (unsupported)
  • properties for operations performed after knife should be available - this way they could be re-executed after property change in f6 panel.
In attached blend file I do simple macro (simple_operator): - subdivide mesh (in edit mode) - perform cut with knife tool, by user - deselect all. [macroUndoStackBroken.blend](https://archive.blender.org/developer/F224857/macroUndoStackBroken.blend) - blend file with macro Now, I know knife tool dosen't support undo, so it is greyed out in F6 panel, after executing this script and calling operator. But undo stack order is reversed from what I see. ![UndoBlend.jpg](https://archive.blender.org/developer/F224859/UndoBlend.jpg) What I mean is, operations performed by macro, after knife_tool, should have available undo properties, but they are disabled. What blender does is, it enables F6 properties, for operations performed before knife. This makes no sense, because as soon as you change property of operator performed before knife, knife operation gets cancelled, and everything after that gets canceled too. So you loose all operations performed after knife operation. How undo stack should work for macro is: - all F6 properties for operations performed before knife should be disabled (unsupported) - properties for operations performed after knife should be available - this way they could be re-executed after property change in f6 panel.
Author
Author
Added subscriber: @JoseConseco
Member
Added subscriber: @Blendify
Added subscribers: @ideasman42, @Sergey
Campbell Barton was assigned by Sergey Sharybin 2015-08-24 10:50:39 +02:00
Don't really think we can support any operator re-do here, afair macro is being re-executed completely, meaning operators both prior and post knife can not be redone.
@ideasman42, mind having a look here? Thanks :)
Don't really think we can support any operator re-do here, afair macro is being re-executed completely, meaning operators both prior and post knife can not be redone. @ideasman42, mind having a look here? Thanks :)
This issue was referenced by blender/blender@74fae33ee5
This issue was referenced by blender/blender@74fae33ee550336c5eb343873ea9c38605e5802f
5 Participants
Reference: blender/blender-addons#45825
