openexr bug #45839
5 Participants
Reference: blender/blender#45839
win7 64bit, GTX650ti
Broken: 2.75a
Worked: 2.74
I used file output node set with openexr file type to output render layers and render passes . When I wanted to use these openexr file to composite, I found the image input node only showed one render layer.
I had create a file named "bug", you can use this one to create a openexr file. I also created a file named "bug_1" with openexr file.
{F225064}bug_1.blend
1, open the bug_1 file, then use view node to check each output node of the image node. Only one render layer can show up and work. If open the bug_1 file with 2.74, every output node of the image node works.
Added subscriber: @b1657022405
#46033 was marked as duplicate of this issue
Added subscriber: @mont29
Looks like this has been fixed already, please check with the latest build from our buildbot.
Changed status from 'Resolved' to: 'Open'
I just test with 2.75-5668fc0, and the bug still exists.
Cannot reproduce here. Please attach here also the .exr file.
here is the exr file :
Oh, OK, sorry, it’s me who did not understood correctly the issue…
Can confirm something is wrong here, either on writing or reading side, will check.
Added subscriber: @Sergey
Caused by
479b6696
, which removed iuser->pass index, leading to only select passes based on their view and type. This may work with pure-render result, but certainly not with random composite OpenEXR images. Thinks you need to re-introduce pass index here… @Sergey may also have some ideas?Setting to high because this should really be fixed before 2.76 imho.
sigh yes I think pass index will have to be back
Proposed fix at D1504
Added subscriber: @GurayGursoy
This issue was referenced by
5317dc716e
