Garbage output in Viewport with OpenSubdiv device set to GLSL Compute #45909
Closed
opened 2015-08-26 08:46:16 +02:00 by Anshu Arya · 6 comments
Using OpenSubdiv on an AMD A10-6800K and A10-7850K on Win8.1 or Win10 with OpenSubdiv and compute device GLSL Compute results in garbage output for Dragon blend example. Also results in random artifacts with other scenes. Other compute devices for OpenSubdiv do not show errors.
Example output of "GLSL Transform Feedback" device:
Example output of "GLSL Compute" device:
SystemInfo for A10-6800K: systeminfo.txt
Using OpenSubdiv on an AMD A10-6800K and A10-7850K on Win8.1 or Win10 with OpenSubdiv and compute device GLSL Compute results in garbage output for Dragon blend example. Also results in random artifacts with other scenes. Other compute devices for OpenSubdiv do not show errors. Example output of "GLSL Transform Feedback" device: ![GLSLTransformFeedback.png](https://archive.blender.org/developer/F228065/GLSLTransformFeedback.png) Example output of "GLSL Compute" device: ![GLSLCompute.png](https://archive.blender.org/developer/F228063/GLSLCompute.png) SystemInfo for A10-6800K: [systeminfo.txt](https://archive.blender.org/developer/F228067/systeminfo.txt)
Author
Sergey Sharybin was assigned by Anshu Arya 2015-08-26 08:46:16 +02:00
Author
Added subscriber: @anshuarya
This issue was referenced by 6ca12d157f
This issue was referenced by 6ca12d157fbfdf1a71a06a87fb5f258ae98ebe02
Author
Forwarding info from Qun Lin:
"It is an application issue. Application forgot to specify the block layout for all shader storage blocks in compute shader.
They assume the default layout is std430. But according to spec, the default layout is shared, which layout is dependent on driver’s implementation, and app should query each member’s offset if they want to use shared layout.
To fix this issue, application only needs to add following line at the beginning of the shader source code:
layout(std430) buffer;
Attached is modified compute shader, in case you need it. With these modified shaders, corruption disappears."
Links to compute shader code referenced above:
https://dl.dropboxusercontent.com/u/3047603/computeshader1.txt
https://dl.dropboxusercontent.com/u/3047603/computeshader2.txt
Forwarding info from Qun Lin: "It is an application issue. Application forgot to specify the block layout for all shader storage blocks in compute shader. They assume the default layout is std430. But according to spec, the default layout is shared, which layout is dependent on driver’s implementation, and app should query each member’s offset if they want to use shared layout. To fix this issue, application only needs to add following line at the beginning of the shader source code: layout(std430) buffer; Attached is modified compute shader, in case you need it. With these modified shaders, corruption disappears." Links to compute shader code referenced above: https://dl.dropboxusercontent.com/u/3047603/computeshader1.txt https://dl.dropboxusercontent.com/u/3047603/computeshader2.txt
Author
This has been solved by: https://github.com/PixarAnimationStudios/OpenSubdiv/pull/742
When Blender pulls in OpenSubdiv v3.0.3, corruption should be gone.
This has been solved by: https://github.com/PixarAnimationStudios/OpenSubdiv/pull/742 When Blender pulls in OpenSubdiv v3.0.3, corruption should be gone.
Reference: blender/blender#45909
