Screw modifier screwed up #45921
Reference: blender/blender#45921
Hi,
In the recent version 2.75a the screw modifier is completely messed up, especially with the bevel modifier.
It worked just fine in 2.74
I'm attaching a sample. The info txt is in the blend.
As you can see, no matter which options, it's screwed up
1: Calculate order and flip normals creates inverted bevels but it would have worked just fine in 2.74. ->Unusable
2: Only calc order. Bevel works fine but but normals are flipped -> unusable. A flip normals modifiers would be handy but that's beside the point.
3 and 4: Only flip or nothing at all, with messed up results -> unusable.
5: My solution I've found so far is have calc order and flip activated, but only rotate it for 180° and mirroring it before adding the bevel and then it works fine. But it would be nice if it worked properly without the workaround.
Blend file: Screw Bug.blend
Best regards,
Nik
Added subscriber: @Kroeterich
This comment was removed by @Kroeterich
Added subscriber: @ideasman42
I can't seem to be able to edit my post.
"1: Calculate order and flip normals creates inverted bevels but it would have worked just fine in 2.75." was meant to be 2.74. It would have worked in 2.74, but doesn't in 2.75a. I haven't tested it in 2.75 since I went from 2.74 straight to 2.75a
Added subscriber: @Sergey
This issue was referenced by
c5f9255eed
