Cycles texture interpolation bug #45946
Closed
opened 2015-08-29 08:01:34 +02:00 by Robert M · 7 comments
Debian AMD64, fglrx-driver
Broken: current master
The texture interpolation shows artefacts near the 0.0 UV coordinates.
This issue appears in Linear, Cubic and Smart mode, and only in conjunction with 'Clip' or 'Extend' extrapolation.
The interpolation setting 'Closest', and extrapolation option 'Repeat' are free from those artefacts.
Here is a blend file:
texture_interpolation_bug.blend
  1. Set 'Viewport Shading' to 'Rendered'
  2. change settings on the texture node (interpolation(Linear, Cubic, Smart, Closest) and extrapolation(Clip, Repeat, Extend))
**System Information** Debian AMD64, fglrx-driver **Blender Version** Broken: current master **Short description of error** The texture interpolation shows artefacts near the 0.0 UV coordinates. This issue appears in Linear, Cubic and Smart mode, and only in conjunction with 'Clip' or 'Extend' extrapolation. The interpolation setting 'Closest', and extrapolation option 'Repeat' are free from those artefacts. **Exact steps for others to reproduce the error** Here is a blend file: [texture_interpolation_bug.blend](https://archive.blender.org/developer/F228898/texture_interpolation_bug.blend) 1. Set 'Viewport Shading' to 'Rendered' 2. change settings on the texture node (interpolation(Linear, Cubic, Smart, Closest) and extrapolation(Clip, Repeat, Extend))
Author
Author
Added subscriber: @robertm
Member
Added subscriber: @GregZaal
Member
Screenshots...
Linear interpolation:
Closest:
Screenshots... Linear interpolation: ![2015-08-29_10-20-14.png](https://archive.blender.org/developer/F228927/2015-08-29_10-20-14.png) Closest: ![2015-08-29_10-21-21.png](https://archive.blender.org/developer/F228929/2015-08-29_10-21-21.png)
Sergey Sharybin self-assigned this 2015-08-29 11:09:21 +02:00
This issue was referenced by 0bc4bc2e61
This issue was referenced by 0bc4bc2e616bc860634bb3b4a637c3400dc5c68f
This issue was referenced by blender/cycles@745fe20eb1
This issue was referenced by blender/cycles@745fe20eb1dab488ac57c9fb1be7ff62f57b17f9
Reference: blender/blender#45946
