Python debugger cannot display source for scripts #45955
Reference: blender/blender#45955
System Information:
Windows 7 Enterprise 64 bit
Blender 2.75a 64 bit official windows build
Python 3.4.2 64 bit official windows build from python.org
Python debugger cannot display source for scripts. To reproduce, run the attached script "bug.py" from command line like this:
blender.exe --background --python bug.py
1
2
(Pdb)
Compare this to output from python:
python.exe bug.py
1
2
I also tested and reproduced the same bug with the ipdb and pycharm debuggers.
bug.py
Added subscriber: @gbantle-3
Added subscriber: @mont29
Thanks for the report, but no bug here… Embedding python implies some differences from the vanilla interpreter - here Blender reads given py scripts and feeds interpreter with that text, so py indeed does not have access to the file itself (for windows only, due to likely different versions between Blender C lib and python C lib - sigh).
Hi Bastien,
Thank you for the quick response.
Am I to understand this means it's simply not possible to debug python scripts on windows? Is this limitation documented somewhere?
It’s not impossible at all, you just do not have access to main file's name in this case, that’s all. Should not be a big issue, since you know which file you passed to Blender's options. ;)
Hi Bastien,
Thanks for the response.
I don't fully agree that since the developer knows the name of the source file all is well, although it certainly helps. I think the relevant point is that since pdb doesn't know the name of the file it no longer works as intended and pdb ships with blender on windows.
Even more interesting, say you don't want to use pdb (which admittedly is not too useful compared to more advanced debuggers), it seems this same issue prevents stack traces from printing properly when unhandled exceptions are thrown. Compare what happens when you run the attached script bug2.py in Blender to what happens when you run it with python.
Blender:
ZeroDivisionError: division by zero
Blender quit
Python:
Admittedly all is not lost since the line numbers are preserved and you can cross reference it with your source file by hand to see the actual content of the offending line. However the way Blender does it right now is not too useful when you just want to get a quick look at the error and the code that caused it. Further it may be quite confusing to someone who doesn't know the technical reasons behind this behavior.
Regardless, my motivation here is simply to advocate for a solution that helps others who might run into this same issue in the future. Thanks to your help I know what the problem is and can easily work around it (I just wrote a wrapper which imports my other code that can then be debugged as normal). However this was after quite a bit of confusion on my part and tinkering with the configuration of my debugger. It would be nice if others don't have to go through the same thing in the future.
Hi @gbantle-3, we had a surprising amount of trouble with Python on Windows, (can't use
PyRun_File
because of incompatibleFILE
structs), nevertheless, this is possible to support - looking into it.This issue was referenced by
5f64b77ca5
Changed status from 'Archived' to: 'Resolved'
