CPU OSL Cycles crashes blender in latest GIT (353d023
) with barcelona scene. #47120
Reference: blender/blender#47120
W7 x64
Broken: Latest GIT (04 01 2016), build with Cmake. Build from 30.12.2015 late in night also crashes (own modifs, so no usefull hash to provide)
Worked: build from 29 December (made with scons)
OSL rendering with packed images makes cycles crash after sometime. First an error message appears , but render continues, then Blender crashes completely.
Open attached file, hit F12 bug osl.blend
Added subscriber: @bliblubli
Added subscriber: @Sergey
Will have a look today.
I can not reproduce the issue on neither Windows nor on Linux using debug builds (on Linux address sanitizer is active). Hence several questions:
Yes it happens with the latest buildbot from today 05012016. By reopening the file, I noticed that it switch automatically to GPU rendering if availaible. So you may have tested with GPU and thus without OSL. I don't know why it does so, because I save with CPU rendering on factory settings, so it can't be due to an addon.
What about reaimining questions?
Sorry, yes it happens with fullscreen and locked interface. When I had both, it crashed instantly the first time, but when doing it again, it took more time. The moment where it happen seems to be somehow random...
By the way, I tried to simplify the case without success. Simple files don't crash, at least, i couldn't get them to crash. But other production files I can't share do (now that we use OSL with packed images :D)
For the background mode, it didn't crash, but it also rendered faster, so I should try more to see if it was just luck.
yipi, succeed in background mode :) :
Still can not reproduce locally on neither the systems here..
Can you test this patch:
P310: Snippet for #47120
There is no link to your patch as far as I can see. Did you set it to CPU rendering on your computer before starting the rendering? I don't know why, but it set it to GPU automatically and I can't change this behavior.
Patch is inlined to the comment.
Ofcourse i switched to CPU, But finally i managed to rdo the issue with the build from bildbot. Annoyingly, it requires to wait for quite some time before the issue is visible. Will try to nail something down.
This issue was referenced by
03302fd5ed
The issue should now be fixed. Let me know if it's still fails for you in sme way.
Just tested it many times. Crash still happened once. This time instantly in the UI before the first tile was rendered. But after that, background rendering worked successfully 3 times and UI render also... So it looks like it's solved but I'm not 100% sure. anyway it's better :)
This is likely to be caused by threading conflict in particles between viewport and render thread. Rendering in full screen mode or with locked interface solves those crashes.
Yep, after 2 days of rendering in Fullscreenmode, the problem didn't show up anymore. Never had this particle problem before but it works now, so I'm happy :)
This issue was referenced by blender/cycles@81b7701941
