EXCEPTION_ACCESS_VIOLATION crash when removing modifiers or rendering #47715
5 Participants
Reference: blender/blender#47715
Windows 10 64-bit, Nvidia GTX 570
Broken: 2.76b,
7499fcf
(latest 2.77 64-bit build)Worked: -
I have a specific file that immediately crashes (blender closes without warning) when rendering or when removing any modifiers (apart from the first 2) on a specific object. I have simplified the file as much as I can.
All crashes result in 'EXCEPTION_ACCESS_VIOLATION' being displayed (when running blender from the command line). 99% of the time that's the error, I did once see a 'divide by zero' error.
Just in case it is important, the object 'Shrinkwrap 2' (the target of the second shrinkwrap modifier) also uses 'Shrinkwrap one' (the target of the first shrinkwrap modifier) as the target on its own shrinkwrap modifier.
Using this file: Shrinkwrap Crash.blend
File instantly crashes.
Alternatively:
Added subscriber: @RayMairlot
Added subscriber: @sindra1961
If you run blender with --enable-new-depsgraph, this will not occur.
Added subscriber: @Sergey
This is a threading conflict. New depsgraph perhaps has different timing which avoids the crash, root of the issue is outside of the depsgraph.
Added subscribers: @mont29, @ideasman42
Yeah… Same old issue again, modifiers using a DM from another object are a real problem (here,
ShrinkwrapCalcData.target
DM), we hit that issue several times in the past already.Manage to fix part of the issues here by making a local copy (
CDDM_copy
) of it inshrinkwrapModifier_deform
, but even then, manage to get a crash (likely because the target->derived_final was being freed while being fetched/copied in other thread).We could:
derivedFinal
.derivedFinal
(and be threadsafe too of course).Or also, use a (thread-safe, trivial with atomic ops) refcount for DMs maybe? This would also avoid the need to copy other-objects DM in modifiers…
@mont29, modifiers are totally allowed to use other object's derived mesh. There are two possibilities here:
Once those points are ensured none of local DM copy or refcounting are needed.
This issue was referenced by
94a6019a7b
