Solidify modifier fails on twisted quad. #48084
Reference: blender/blender#48084
system-info.txt
Broken: 2.77
65f279b
The solidify modifier fails when it's working with a 4-vertex plane that is slightly twisted. The generated face will intersect with the original face slightly in the center.
In the attached blend file there's a mesh with two separate faces, each twisted a little; and a solidify modifier. Both faces have intersecting centers. Oddly, if you check
Flip Normals
on the solidify modifier, they no longer intersect...Solidify-Fail.blend
Added subscriber: @IsaacWeaver
Added subscribers: @ideasman42, @mont29
This is due to how tessellation happens (you can 'preview' it with triangulate modifier, 'fixed' quad method)…
Though I would not consider this a bug, maybe we could handle this situation better, @ideasman42?
I just realized that when using the solidify tool in edit mode on the exact same mesh with the same thickness, it works just fine without any intersections. I would expect these tools to work the same...
This isn't a bug strictly speaking, but its not a big change to ensure the first vertex in both faces is the same, then the remaining vertices are flipped.
Have a change prepared, will test further and commit if all goes well.
This issue was referenced by
e5a2790ecb
