Missing elements from Collada file (import) #48389
Reference: blender/blender#48389
Windows 10
Broken: Blender 2.77a
Import collada file throws an error, and has missing geometry.
Import Collada: ZINCARB65_ZC_313343_P.zip (unzip the file first)
Result in Blender:
Result in 3D Builder (Windows default .dae opener):
Reference object (photo):
I get the following message from Blender. Note, I get a similar message with any .dae I try to import from my collection. But this is the only one with missing geometry.
Added subscriber: @dfelinto
Added subscriber: @Sergey
The Collada importer just reports some minor issues in the collada file. And admitedly it reports its concerns in a somewhat exagerated and misleading way.
Lets look at the first reported error:
When i inspect the reported line in the collada file then i find this:
The interpretation of the reported error line is as follows:
This attribute is reported but ignored. We could improve the report by making it less verbose and more precise, for example like:
I am looking at this now and check if the collada parser reporter can be made more user friendly.
As requested, those are simpler sample files: holed_mesh.zip
They all import fine on SketchUp (where I generated them), but the non-triangulated ones do not ipmort correctly on Blender or Meshlab.
As discussed in IRC: The missing geometry happens because the Collada importer discards faces with holes. This is a known issue. I tried to fix this last year but i could not find a good way to solve it.
Campbell mentioned yesterday (in IRC) that the file scanfill.c contains functions which are used by python importers to solve the import of faces with holes. I will look at this next and see if i can solve this issue. However it can take a few days.
Another example of a simple file (manually simplified): WINCAR75.dae
The file opens fine-ish in SketchUp, but in Blender it presents the same problem as the original one.
In case it helps debugging, this is the original WINCAR75 as well as a triangulated version of its problematic part, and the original .fbx the collada files were exported from.
WINCAR75_all.zip
As requested, the top plane only: WINCAR75_top.dae
And at last, a very simple face with a hole: holes.dae
Collada supports faces with holes by using at least 2 approaches:
that contains the polygon (as closed loop of verts) and one or more subelements each containing a hole (also as closed loop of verts).
Now the task is to break up the "face with holes" into a set of subfaces that contain no holes and no duplicate edges. (to be continued...)
@GaiaClary now that we have a more clear picture of when the problem happens, how much trouble would be to add a printing warning for those cases? Knowing which of my imported files are broken would help my use case tremendously already.
This issue was referenced by
b000a01725
Changed status from 'Resolved' to: 'Open'
Automatic close was wrong. this is work in progress (we still want to support the import of polygons with holes).
Added subscriber: @GaiaClary
