Changing Renderlayer Compositor node Layer does not update enabled outputs until script is finished #48760
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#48760
GNU/Linux 64 bit (Fedora 23), Intel CPU, Nvidia GPU
Broken: 2.77.1 2af4c80
Worked: maybe never
If you add change a renderlayer node's scene layer, the enabled output sockets change to reflect the scene layer's enabled passes. But if you do this within a python script or function, this does not happen until after the script has finished running, making it extremely cumbersome to use this node in your script (scene layer passes are not 1 to 1 the same as node layer output names, e.g. Combined -> Image, Alpha, Object Index ->IndexOB etc.)
Note that the two renderlayers in the scene (A and B) have different passes
What I Expect to Happen
At least with some type of refreshing (note the overkill_update() function in the script) I would expect the output to change on the second print_enabled_sockets() command to reflect the renderlayer change.
Added subscriber: @BassamKurdali
bug2.blend
I added a bpy.context.scene.node_tree.update_tag()
bpy.context.scene.update()
just in case, to the overkill_update() function. Same result.
Added subscribers: @monique, @Sergey, @Jeroen-Bakker, @mont29
Can confirm the issue, it comes from the fact that your newly added node has no output (
ED_node_tag_update_nodetree
is called from RNA update callback, but does nothing in case node is not connected somehow to output - i.e. node has no effect on result). And RenderLayer node has no update() callback registered either, afaict.Not sure how to handle this, @Jeroen-Bakker, @monique, @Sergey?
@mont29,
updates nodetree itself (aka, executes the tree to get new result).The actual issue here is that currently sockets gets hidden on every redraw of compositor. This is weak, but it is how it is. Tweaking render passes forces updates of hidden sockets, so guess it'll be fine to do same for layer in Image and Scene compositor nodes.
This issue was referenced by blender/blender@ae881ddf43
wow! thanks sergey and mont, that was an interesting/ difficult case!
