Crash during access to dupli weights #49273
Reference: blender/blender#49273
The crash is happening only when you invoke the attached script by passing it to Blender through command line.
=> Crash
If you will run similar script when Blender is being already loaded, there is no crash:
dupli_weights_crash.zip
I suppose that the old pointer is not updated.
Added subscriber: @AlexanderRomanov
Added subscriber: @mont29
Something seems to be going bad in readfile.c's
lib_link_particlesettings()
, not sure why code here is so much intricated :/Yuck… issue is actually very hairy. :(
Problem is,
is assuming its dup_group Group is already fully valid (i.e. its object pointers are valid), which is not the case if dup_group is linked from a library not yet processed. That, and the fact that object assigned to dw->ob are not considered as “real reference”, i.e. it’s not enough to consider said object as directly linked, afaict.I’m terribly tempted to just NULL-ify those dw->ob pointers, and let later code reset them to correct value, when valid indices are available… Means you'll get 'No Object' from your script at startup, but won't crash, and particle code seems to nicely re-populate those pointers later (probably on update).
uuur… but setting dw->ob to NULL forces the system to recreate dummy dupliweights with all same '1' value :(
this needs further investigations…
Added subscribers: @AlexKowel, @EvgenyRodygin, @yurikovelenov
Added subscriber: @Sergey
OK, have a patch fixing this, would not mind @Sergey having an eye on it before I commit it though…
P391: #49273
OK, so after discussing it with Sergey we decided it was not a good idea to hack in readcode, especially not for something that is doomed to complete rewrite, and even worse, for something that is purely runtime caching helper.
So will instead slightly modify 'update' code of particles' duplis to restore correct
dw->ob
pointers. This means you won't have correct values fordw.name
until you update the scene.This issue was referenced by
bcc863993a
Thanks! It's better then crash!
