OBJ importer cannot deal with texture names with spaces #49357
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#49357
Not relevant
Latest (2.78)
The OBJ importer, when processing the MTL cannot deal with material images cannot parse filenames with spaces.
Load any OBJ with textures with spaces on the filename.
On the code: https://developer.blender.org/diffusion/BA/browse/master/io_scene_obj/import_obj.py
This line of code only uses the last separated-by-space part of the MTL line content. If the filename is (without quotes) "blue 3.jpg" the imagepath will be "3.jpg" instead of "blue 3.jpg". Just a bad parse.
This will result in Blender trying to load an image that does not exist.
Thank you for any effort to resolve this.
Added subscriber: @tiago.cardoso
Added subscriber: @mont29
Thanks for the report, but no bug here, MTL does not support filenames with spaces, which is quite obvious since it uses spaces to separate options… Some programs are not smart enough to cope with this limitation when exporting, but we cannot do anything about it.
I haven't seen any indication on MTL specifications that prohibits spaces in the filename.
All the args options and parameters are well defined on the specs and could be taken in account, eg. after that code line, the last token is getting too much parameters (the begining of the filename) with no need. All options have a set number of parameters.
Just need to do a regular expression to eliminate options as it's parameters and you can get the complete filename.
It's not simple, but I think, very feasable and would be a great improvement :D
Thank you
^\S+(\s-(((blenu|blenv|bm|boost|cc|clamp|imfchan|texres)\s[^-]\S+)|(mm(\s[^-]\S+){2})|(s(\s[^-]\S+){3})))*\s
If I've not made a mistake somewhere, this regex should work. Just remove what it grab and you have the filename, with or without spaces.
Could you test and commit it (if correct) ? :) It would be great.
Thank you!
That won't work in all cases, see e.g. the
-o
/-s
/-t
options, which can have optionalv
/w
? Is it file"2 3 foo.png"
?Short answer/fix: do not use spaces in your filenames in OBJ context, this is not designed to support it, and will always make things harder, whatever solution is hacked around.
Will try some workaround though (like going backward adding items to 'potential' filename until we find an existing match), but this won't probably cover all cases anyway.
My regex is missing some options:
^\S+(\s-(((blenu|blenv|bm|boost|cc|clamp|imfchan|texres)\s[^-]\S+)|(mm(\s[^-]\S+){2})|((s|o|t)(\s[^-]\S+){3})))*\s
This should be it. Options like -o, -s or -t always have 3 parameters, so the regex accounts for that and the name should be just foo.png.
As the number of parameters is static for each option. A regex should be able to parse it, no ?
Can you see another case that wouldn't work ?
Thank you
Read the specs, v and w are optional, so there is no guarantee you'll have three params here…
You're right.
But we could use :
!!^\S+(\s-(((blenu|blenv|bm|boost|cc|clamp|imfchan|texres)\s[^-]\S+)|(mm(\s[^-]\S+){2})|((s|o|t)(\s\d(.\d+)?){1,3})))*\s!!
This would take in account those optional parameters. It will check only for number as parameters (specs) and never "eat" the texture filename.
The only (I think) time this could be wrong is in similar cases to the one that you provides, but it would return !!foo.png!! that is what you are already returning. So we do not had any more wrong cases and resolve a lot a cases that now don't work.
For example, for !!map_Ka -o 1.0 2 bar foo.png!! it would leave !!bar foo.png!! that might not be the correct filename but is way better guess than just !!foo.png!! that is what is happening right now.
I think this would improve much the situation we have right now. It's a perfect build on what there is now as it reduces the number of times it gets the wrong filename and doesn't add any more wrong filename that it already gets.
For my use case, this is very importing, as we are using Blender to render files and a lot of files (in OBJ) appear with spaces (and we cannot change it as we do not control the files that we get.
Do you agree that this would just reduce the amount of wrong file_paths without getting any other side effects ?
Once again, thank you!
This issue was referenced by
d98fc12f8d
959f9d28d2
+1 Thanks!
