fbx2json.py crashes when parsing fbx files with a version number = 7500 (I haven't tried others) #49822
Closed
opened 2016-10-23 15:04:11 +02:00 by Raul Aguaviva · 8 comments
I actually fixed the script to support these new version fbx's, you can diff with yours to see what the fix is
fbx2json.py
Cheers!
I actually fixed the script to support these new version fbx's, you can diff with yours to see what the fix is [fbx2json.py](https://archive.blender.org/developer/F384951/fbx2json.py) Cheers!
Bastien Montagne was assigned by Raul Aguaviva 2016-10-23 15:04:11 +02:00
Author
Author
Added subscriber: @xchip
Thanks for the fix, but this is not acceptable as-is, since you are therefore breaking all pre-7500 files with those changes (sizes should be switched after having read version imho).
Anyway, this is trivial to fix, but more importantly here, did you try that change in actual parsing code, and then importing a .fbx file in Blender?
Thanks for the fix, but this is not acceptable as-is, since you are therefore breaking all pre-7500 files with those changes (sizes should be switched after having read version imho). Anyway, this is trivial to fix, but more importantly here, did you try that change in actual parsing code, and then importing a .fbx file in Blender?
Author
I said I fixed but I meant that I found out what the issue with the new version is. What I did was a quick change to show you where the problem is.
OK, will take over from there and try and see if this is enough to make new format work.
Thanks looks like that was the only issue with new FBX indeed, so now Blender can import FBX2016 too. :)
Author
My pleasure! Thanks to you for your prompt support :)
2 Participants
Reference: blender/blender-addons#49822
