Segfault when copying object data of linked object #49905
Closed
opened 2016-11-01 23:00:19 +01:00 by FeepingCreature · 7 comments
I'm doing a MagLev mod for Space Engineers, and all the rail pieces are just linked to the same 1x1 rail piece with array and curve modifiers.
I'd accidentally kept a curve piece linked to the original, so I tried to make a single copy. Doing so reproducibly crashes Blender.
This happens on Windows 7, 64-bit, 2.77, 2.78 and November 1 Nightly. I used an addon for Space Engineers modding, but the issue happens when it's disabled as well.
Steps to reproduce:
  • Open attached (minimal) Blender file HoverRailCrashing.blend.
  • On the tool panel on the right, click - to make a single-user copy. Blender crashes with Error: EXCEPTION_ACCESS_VIOLATION.
Interestingly, the crash does not happen if you delete the collision geometry on layer 2 first.
I'm doing a MagLev mod for Space Engineers, and all the rail pieces are just linked to the same 1x1 rail piece with array and curve modifiers. I'd accidentally kept a curve piece linked to the original, so I tried to make a single copy. Doing so reproducibly crashes Blender. This happens on Windows 7, 64-bit, 2.77, 2.78 and November 1 Nightly. I used an addon for Space Engineers modding, but the issue happens when it's disabled as well. Steps to reproduce: * Open attached (minimal) Blender file [HoverRailCrashing.blend](https://archive.blender.org/developer/F390200/HoverRailCrashing.blend). * On the tool panel on the right, click - [x] to make a single-user copy. Blender crashes with Error: EXCEPTION_ACCESS_VIOLATION. Interestingly, the crash does not happen if you delete the collision geometry on layer 2 first.
Added subscriber: @FeepingCreature
Hit another crash. I suspect it's the same one. This one happens because I have the materials linked to object instead of data? Same steps to reproduce, click - [x] on the right and it crashes.
File: HoverRailCrashing2.blend
Hit another crash. I *suspect* it's the same one. This one happens because I have the materials linked to object instead of data? Same steps to reproduce, click - [x] on the right and it crashes. File: [HoverRailCrashing2.blend](https://archive.blender.org/developer/F390886/HoverRailCrashing2.blend)
Added subscriber: @mont29
Bastien Montagne self-assigned this 2016-11-04 09:55:10 +01:00
Yep, both cases have same cause, fix incoming.
This issue was referenced by blender/blender@f0ac661aa8
This issue was referenced by blender/blender@f0ac661aa8362f5c990b238a2366e2730cd4cb72
Reference: blender/blender-addons#49905
