VSE: Cutting a strip that is crossfaded causes the crossfade effect input to be changed to the wrong cut strip #50877
Closed
opened 2017-03-07 03:32:05 +01:00 by hudson barkley · 10 comments
Broken: 2.78c
When two strips are connected by an effect strip (cross or wipe effect), and the left strip is cut, the effect will change its first input to the left cut piece, thus causing the effect to change its position and length (and usually end up overlaid on the same channel as the right cut strip).
The effect should be connecting the right cut piece and the original far right strip.
  1. Add two videos to the VSE
  2. Add a crossfade effect strip between the two videos
  3. Select and cut the left strip in a position before the left side of the effect strip
**Blender Version** Broken: 2.78c **Short description of error** When two strips are connected by an effect strip (cross or wipe effect), and the left strip is cut, the effect will change its first input to the left cut piece, thus causing the effect to change its position and length (and usually end up overlaid on the same channel as the right cut strip). The effect should be connecting the right cut piece and the original far right strip. **Exact steps for others to reproduce the error** 1. Add two videos to the VSE 2. Add a crossfade effect strip between the two videos 3. Select and cut the left strip in a position before the left side of the effect strip
Author
Author
Added subscriber: @snuq
Added subscriber: @dfelinto
Confirmed.
For sample file: vse.blend
(use video file from: http://download.blender.org/peach/trailer/trailer_400p.ogg )
See .gif: vse.gif
Confirmed. For sample file: [vse.blend](https://archive.blender.org/developer/F599362/vse.blend) (use video file from: http://download.blender.org/peach/trailer/trailer_400p.ogg ) See .gif: ![vse.gif](https://archive.blender.org/developer/F599376/vse.gif)
Dalai Felinto self-assigned this 2017-05-15 16:09:35 +02:00
Added to the VSE TODO: https://wiki.blender.org/index.php/Dev:Source/Development/Todo/Editors#Video_Sequencer Thanks for the report.
Added subscriber: @tintwotin
@iss This bug-report is still valid and should be reopened:
{F9637289,size=full}
@iss This bug-report is still valid and should be reopened: {[F9637289](https://archive.blender.org/developer/F9637289/Wrong_transition_input_assigment_when_cut.gif),size=full}
Added subscriber: @iss
Added subscriber: @ckerr
Reference: blender/blender#50877
