CUDA error: Illegal address in cuCtxSynchronize(), line 1366 #51568
Closed
opened 2017-05-20 11:33:01 +02:00 by interlichtspielhaus · 11 comments
Linux/GeForce GTX 1060
latest source from master
open file http://interlichtspielhaus.org/blender/untitled.blend
switch the 3D View to Rendered
error occurs:
Refer to the Cycles GPU rendering documentation for possible solutions:
https://docs.blender.org/manual/en/dev/render/cycles/gpu_rendering.html
CUDA error: Illegal address in cuCtxSynchronize(), line 1829
CUDA error: Illegal address in cuMemcpyDtoH((uchar*)mem.data_pointer + offset, (CUdeviceptr)(mem.device_pointer + offset), size), line 577
Linux/GeForce GTX 1060 latest source from master open file http://interlichtspielhaus.org/blender/untitled.blend switch the 3D View to Rendered error occurs: CUDA error: Illegal address in cuCtxSynchronize(), line 1366 Refer to the Cycles GPU rendering documentation for possible solutions: https://docs.blender.org/manual/en/dev/render/cycles/gpu_rendering.html CUDA error: Illegal address in cuCtxSynchronize(), line 1829 CUDA error: Illegal address in cuMemcpyDtoH((uchar*)mem.data_pointer + offset, (CUdeviceptr)(mem.device_pointer + offset), size), line 577
Added subscriber: @intrah
Added subscriber: @Sergey
Sergey Sharybin self-assigned this 2017-05-20 14:18:09 +02:00
Attached file here so it is never lost: untitled.blend
Don't currently have access to CUDA-enabled device, will test this on Monday.
Attached file here so it is never lost: [untitled.blend](https://archive.blender.org/developer/F604795/untitled.blend) Don't currently have access to CUDA-enabled device, will test this on Monday.
Added subscriber: @Erdinc
Same issue here,
It has broken after this commit.
177385dc43
Same issue here, It has broken after this commit. https://git.blender.org/gitweb/gitweb.cgi/blender.git/commit/177385dc439b4f6b478a033413a8df992e7f5ed3
Added subscriber: @MaiLavelle
Interesting. @MaiLavelle might also be interested to look here then.
This issue was referenced by blender/cycles@a92582af23
This issue was referenced by blender/cycles@a92582af23a6ee7574a8405cd051975d1ce25a2a
This issue was referenced by 34b689892b
This issue was referenced by 34b689892b29d618394c6d17c5d29129500185c4
Reference: blender/blender#51568
